Old 11-05-13, 03:38 PM   #1
coombest
Default SV650SK3 Parts for sale (lots!!) **UPDATED!!**
I need to raise funds to fix my bike, so have been through the garage and have the following for sale.
Will work out postage for items individually when they sell but I don't take the mickey with postage costs!
I'll get some pics as soon as poss but in the meantime if you want pics, please message me!
All items taken from a 53 registered SV650SK3 which had done about 9500 miles when I was knocked off it by a cretin car driver in November 2004!
What I didn't sell after I bought the wreck back has been sat in the garage since then!
Main frame & swingarm - also has original shock absorber, side stand, side stand switch, aluminium paddock stand bobbins, rear wheel spindle (missing nut, though!), adjusters (missing the gauge big from one side though!).
The frame is registered, I have the V5C and original number plate and it is SORN'ed (no MoT!!). It has not been written off according to HPI check
Appears straight and there is little damage to the frame itself.
BUT
It is damaged. (See pics)
The cross member that sits just behind the headstock (with the really rubbish welding on it!) has cracked the weld on one side, so may be repairable or may be just for spares or race use. - £120
Pillion grab rail in grand candy blue. Looks straight & intact but has scratches all over it - may be able to be resprayed, though! Has the bolts and rubber fairing grommets included. - £5
Standard (MoT!) exhaust can. Only used for first few hundred miles. Neat cut with decent amount of tail to attach to the header. Includes link pipe/sleeve but not goy any exhaust clamps. - £35
Radiator fan. Will check if working when I get the time! - £10
Whole rear brake setup (reservoir, master cylinder, caliper, hoses and even pads!) all still connected. Caliper could do with a strip down as been in storage for nearly a decade! - £25
Original horn. - £3
Right hand (throttle side) mirror. Scuffed mounting point and minor scratch to front of mirror casing but fully functional! - £7 possibly sold
Original little shock mud guard thingy! - £3
Radiator cap, mounting bracket & hose. - £5 possibly sold
Exhaust header stub - looking at pictures online, it would appear to be from the rear cylinder! - £5
Original screen. Light scuffs - will more than likely polish out with plastic polish/ toothpaste! - £10 SOLD!
Throttle bodies. - £35
Expansion tank - cap and hoses still connected. - £10
Black infill panels (the ones from about where your knees sit) one has the front lug missing and the other has the front lug broken but repairable. Should fit fine with one lug and the bolt any way! No major scratches. - £25 the pair
Pillion pegs. - £40 the pair
Original loom with Meta alarm... Pretty sure it's all there! Not sure if I remember where the alarm fobs went though, so may not be much use... Can't find the alarm fobs anywhere but may be of use for parts? - £25
Original regulator/ rectifier. Will see if I can test it before sale (any tips people!?). - £25
Original air filter - only used for a couple of hundred miles before a K&N was fitted! - £5
Original airbox snorkel. - £5
RHS (brake side) footpeg/ rearset. Pedal bent and worn down but serviceable, heel guard tatty as I started to remove the paintwork as was naming on polishing them! - £20
LHS (gear side) footpeg & rearset/ heelguard all intact - will need to make sure all the parts are there though! - £20 SOLD!
HEL stainless braided rear brake line. - £10 SOLD!
Original bar ends (2 pairs) and a pair of DHB bar ends - selling as a job lot as 1 pair badly scuffed with bent bolts and not got all internal grippy fitting/ nuts present - £5 SOLD!
1 x New Motrax micro arrow black & iridium mini indicator. - £2
NEW: Also found a set of body armour inserts. They look to be universal type that can do elbows or knees and shoulders or hips. - £5
Old 11-05-13, 04:48 PM   #2
TheRuffellator
Default Re: SV650SK3 Parts for sale (lots!!)
On the off chance, do you have the rear disc for sale at all?
Old 11-05-13, 05:32 PM   #3
coombest
'Fraid not!
That went with the rear wheel a while back.
Old 11-05-13, 06:00 PM   #4
TheRuffellator
Ah that's a shame, ah well cheers anyway
Old 11-05-13, 06:25 PM   #5
M65
Dibs on the bar ends. Im without any at the minute. Can you send me pics please, especially of the original ones. Ta
Old 11-05-13, 06:30 PM   #6
coombest
Will do...
Will have to dig them out from the bottom of the box!
I'm working tonight til midnight and tomorrow 7am-7pm, so will be sometime from Monday onwards but no worries.
The DHB ones are immaculate as fitted, looked at and not liked!
The others are all reasonable but with minor scratching to the ends of some or all of them.
Old 11-05-13, 08:36 PM   #7
sam-bliss
Can I take the lhs foot peg hangars
Old 11-05-13, 08:48 PM   #8
muzikill
muzikill's Avatar
M65 seeing how theres more than one set of bar ends howsabout a split after youve chose what you want?
Old 11-05-13, 11:36 PM   #9
Antrats73
Antrats73's Avatar
I'll have the hel rear brake line please, pm me with price inc p&p when you get chance buddy cheers!
Sv650 k4, Oxford grips, Rear seat cowl & pad, Pyramid undertray, Tinted screen, Tinted Headlight covers, Mirror Extenders, Xenon bulbs, Blue LED speedo upgrade, Jisu stubby exhaust + hanger, A Gizmo, Cheeky home made LED tail tidy!
Antrats73 is offline   Reply With Quote
Old 12-05-13, 08:11 AM   #10
M65
Originally Posted by coombest View Post
Will do...
Sure, no problem. If you want, send pics of both sets then I can see which ones will suit best.
Originally Posted by muzikill View Post
M65 seeing how theres more than one set of bar ends hows about a split after youve chose what you want?
Sounds like a plan to me.
Lots of parts for sale from 2003 SV650SK3 martynp69 For Sale - SV's and SV related items 4 26-09-12 08:36 AM
lots of parts for sale ** MUST SEE ** joshwalker094 For Sale - SV's and SV related items 20 25-06-12 09:06 PM
sv650 (k2) with lots of parts for sale Madtone For Sale - SV's and SV related items 0 22-03-10 11:40 AM
Silver SV650Sk3 front end parts for sale airbrush_assasin For Sale - SV's and SV related items 0 10-11-09 09:07 AM
For sale: Playstation 2 with lots of bits and pieces inc Buzz & Singstar & Lots more Paul the 6th Idle Banter 3 25-04-08 12:52 PM
