Old 16-05-13, 03:34 PM   #1
lordra
Lightbulb Pillion Screw Problems!
The LHS screw that holds the grab rail in place has eaten the threads of the thingy inside(please forgive my lack of technical terminology) and as a result, the screw keeps turning and the grab rail is loose. There was a lot of silver dust falling out of it.
Where can I get a replacement for them screw things?
Its the silver bits inside...
Old 16-05-13, 07:27 PM   #2
Default Re: Pillion Screw Problems!
The thread is in the subframe. Are you sure the bolt isn't knackered? If the bolt is OK but turns and won't tighten you'll need the subframe thread repaired, at a bike shop or similar ask if they can use a thread insert - often referred to as a Helicoil. There are other similar processes it doesn't need to be that one specifically. If you ask on the phone, tell them you need a thread repair for an M8.
Old 16-05-13, 09:31 PM   #3
NTECUK
NTECUK's Avatar
Drill it out and fit a new Riv Nut
http://www.rivetnut.co.uk/
Old 16-05-13, 09:44 PM   #4
It's not a rivnut, it's a cylindrical pillar about 15mm diameter with a thread down the middle of it.
Old 16-05-13, 10:20 PM   #5
stuR
I have the same problem. Dont do a costly repair on the nut on the subframe, get a longer bolt and attach your own nut inside for it to grip onto. Works for me
Old 16-05-13, 10:42 PM   #6
NTECUK
NTECUK's Avatar
DRILL it our then fit a threaded insert then
Old 17-05-13, 04:58 AM   #7
Dicky Ticker
Drill them out and use a nut and bolt--------simples and cheaper
Old 17-05-13, 11:38 AM   #8
lordra
Talking Re: Pillion Screw Problems!
I've checked both the bolts against each other and swapped them around. The bolts are fine... How much will this set me back by? I'm only part time on min wage, need to keep associated costs down to a minimum... Thread insert. Got it. So this something I can't do myself then...
Old 17-05-13, 11:47 AM   #9
lordra
@ stuR & Dicky Ticker, you guys are simply super! That's the cheapest and easiest DIY solution ever! Where do you get one of those from? A link or a store perhaps?
@ Sid Squid & NTECUK : Cheers for the input guys, I've had a look on the site and I can't seem to find anything that matches what I need! Will stuR and Dicky's method be cheaper?
Old 17-05-13, 12:02 PM   #10
NTECUK
NTECUK's Avatar
the nut and bolt is cheaper.
Some one will have a spare bolt and nut kicking about in there tool box
.ask your local garage or bike buddies.
Pillion Helmet Responsibility (Rider or Pillion)? 18sv650 Bikes - Talk & Issues 17 14-01-13 04:56 PM
Black pillion seat cowl and pillion grab rail off K8 Nobbylad For Sale - SV's and SV related items 3 23-12-09 11:05 AM
Pillion seat cowl removal problems! aliman2000 SV Talk, Tuning & Tweaking 8 05-07-07 05:32 PM
Screw ups The Hairy Hamish Pennine Massive 3 05-05-07 03:43 PM
Two up / Screw up John 675 SV Talk, Tuning & Tweaking 63 06-03-07 11:25 PM
