Old 28-05-13, 11:00 AM   #1
Pricey12
Default Rear cylinder exhaust clamp size? (Curvy)
I need to buy a nice Mikelor one to go with my shiny Arrow exhaust system, just not sure which size to get (and it's a pig to try and get a look at while still on the bike). I'm thinking it's 43-47mm. Can anyone confirm?
Thanks
Old 28-05-13, 11:16 AM   #2
jambo
jambo's Avatar
Default Re: Rear cylinder exhaust clamp size (Curvy)
Is the arrow system definitely the same diameter as OE at that point? Might be worth contacting Arrow if not.
Jambo
Old 28-05-13, 11:19 AM   #3
Pricey12
Good point, hadn't considered that.
I think the Arrow pipes are actually slightly tapered - will have to check.
Old 28-05-13, 01:43 PM   #4
Pricey12
This is the system - looking at the pipes the diameter of the outlets definitely look bigger than stock. Tape measure time I think
Old 28-05-13, 03:32 PM   #5
Pricey12
One thing I've noticed though, is that the two gasket / clamp attachments (no idea what they're called ) at the end of both headers seem to be rubber, whereas on pictures of other systems I've seen they are metal. Do I need to get hold of some metal ones or can I re-use the ones on the bike? (assuming they haven't turned into paper mache like my front header bolts...
Old 28-05-13, 03:52 PM   #6
jambo
jambo's Avatar
If that's what they ship with then that's what you should use, provided they're in decent condition.
I'd use fresh exhaust gaskets, and just assemble it and see if it's blowing anywhere.
Jambo
Old 28-05-13, 03:57 PM   #7
Pricey12
Yeah, they seem in good condition.
Doesn't look like you can get the metal versions without buying the entire section of pipe (at least according to Robinson's parts fiche). I just assumed that seeing as the header bolts go through that part to secure the pipe to the bike they would be metal. I guess Arrow must know something I don't...
Old 28-05-13, 05:16 PM   #8
Pricey12
Upon inspection, turns out they are metal after all (just painted black). I just assumed they were rubber from the photos
Old 29-05-13, 11:22 AM   #9
Pricey12
Default Re: Rear cylinder exhaust clamp size? (Curvy)
Just out of interest, do you actually NEED a clamp on the rear cylinder header pipe?
It seems to attach in exactly the same way as the front header pipe, and obviously that doesn't have a clamp.
Just curious.
Old 29-05-13, 11:36 AM   #10
Nobbylad
Nobbylad's Avatar
There is an exit pipe from the engine, that the actual exhaust clamps onto....
Not sure if your system replaces that piece and the whole lot bolts on?
what size exhaust clamp svdev SV Talk, Tuning & Tweaking 19 08-05-11 03:37 PM
Exhaust Clamp Size? toby_smith SV Talk, Tuning & Tweaking 3 18-05-10 08:32 AM
Universal Exhaust Clamp - What Size? slloyd SV Talk, Tuning & Tweaking 14 17-05-09 05:51 PM
What size clamp for a CCC exhaust? Nobbylad SV Talk, Tuning & Tweaking 13 24-12-08 05:13 PM
Exhaust Clamp size jon SV Talk, Tuning & Tweaking 12 23-05-05 12:29 AM
