Old 03-06-13, 09:17 PM   #1
muzikill
muzikill's Avatar
Default SV hugger part needed
I got hold of a rare as hens teeth oem k3 YC2 hugger (£40 delivered btw)
Has anyone got one of the parts below? it's a rubber grommet & spacer for the rear fixing. i'm making do with another solution but to keep it as original as possible it's worth a go to see if anyone has one.
Old 04-06-13, 03:47 PM   #2
phil24_7
Default Re: SV hugger part needed
Dream on!!! Best you'll be able to do is get a rubber grommet that looks similar (or replace all grommets so they're identical), then replace all bolts with new stainless ones so they all match.
P.S. That's a stonking price for a genuine Suzuki hugger!
Regards
Old 04-06-13, 06:00 PM   #3
muzikill
muzikill's Avatar
Bought off the forum. Seller was sound as. He had a previous offer where the buyer wanted to spraycan it black!. When he knew i wanted yc2 he knew it had a good home to keep it the same.
givi monorack part needed (don't know the name LOL) agy Stuff Wanted 2 12-04-13 06:07 AM
Peugeot 206 part needed Shellywoozle Idle Banter 13 25-08-08 10:01 PM
Starter motor part needed svrash Stuff Wanted 0 18-06-06 02:17 PM
Part time help needed Ed Idle Banter 4 04-03-06 07:21 PM
part needed for yellow sv650s k2 baggies666 Stuff Wanted 0 01-12-05 02:17 PM
