Old 14-06-13, 03:43 PM   #1
GoatMasterUK
Default Fitting aftermarket indicators?
Right, before I hack this to bits, is there a simple way to attach these indicators? I was going to cut the normal OEM plastic extenders down then pop the aftermarket indicators in.
GoatMasterUK is offline   Reply With Quote
Old 14-06-13, 03:55 PM   #2
Pricey12
Default Re: Aftermarket Indicators
You can buy wiring adaptors on ebay. One end attaches to existing wiring and the other end to the aftermarket indys.
Saves you from cutting the wiring.
Old 14-06-13, 04:07 PM   #3
+1 the best way to fit them
Motrax ( ) do them, bullet connectors at one end, Suzuki connector at the other
Old 14-06-13, 04:14 PM   #4
spyrius
try easternbeaver for connectors:
http://www.easternbeaver.com/Main/El.../mitsu_uc.html
unfortunately you need to order more than $20
Old 14-06-13, 04:41 PM   #5
GoatMasterUK
Not too sure on this. I meant for attaching the indicators to the fairing.
Old 14-06-13, 05:05 PM   #6
Get some adaptor plates http://www.ebay.co.uk/itm/SUZUKI-GSX...item2c6f2d41c3
Old 14-06-13, 05:33 PM   #7
Pricey12
Make sure you get the correct adaptor plates. If you have a pointy the above will fit, however if you have a curvy you need ones for a TL1000 as they are a different shape.
Old 14-06-13, 05:43 PM   #8
GoatMasterUK
Thanks for this. I actually didn't have a clue on what to look for. These are exactly it though!
Old 14-06-13, 07:00 PM   #9
That's why this place is so good, lots of helpful peeps on here
Show me your aftermarket indicators philz SV Talk, Tuning & Tweaking 24 02-06-11 11:14 AM
Fitting aftermarket indicators at the front? rharrington0 SV Talk, Tuning & Tweaking 6 09-10-10 04:30 PM
Nut/Screw Size on aftermarket indicators enzyme SV Talk, Tuning & Tweaking 8 28-04-05 04:07 AM
fitting aftermarket indicators 650newb SV Talk, Tuning & Tweaking 16 05-03-05 06:35 PM
Wiring in aftermarket indicators? steve mac SV Talk, Tuning & Tweaking 5 08-02-05 05:41 PM
