Old 18-06-13, 08:42 PM   #1
Littlewebber
Default Oil, then none, now problem
Checked my oil last week and was near the low limit, couldnt top up as had no oil or money so was waiting till this friday when i get paid to replace, anyways riding home today it started a big knocking in the engine, i was only 30 seconds from home so got home and had a little look to see no oil. Now the front cylinder make a knocking sound? I have put oil in it so im guessing ive damadged something inside? What could it be and how much we looking at fixing?
I have a k5 pointy
Old 18-06-13, 10:55 PM   #2
Default Re: Oil, then none, now problem
Hmmmm... it kinda depends on the noise you've got, is the engine making a cyclic knocking, worse on over-run? If yes, there are few, mostly unfortunate, possibilities - low oil and an SV usually means duffed big ends - plain bearings like oil pressure, and respond very poorly to low or no pressure.
Economics dictate a repair is ordinarily not viable, which usually means new motor is one's best option.
You could try putting some oil in and see what happens, you may have got lucky.
Old 19-06-13, 05:56 AM   #3
Littlewebber
Hard to describe the sound, but when you rev it it ets worse and that is with new oil in it now, so you rekon it worth fixing or not?
Old 19-06-13, 07:41 AM   #4
False economy fail there.
I've seen a few cases like this and it's usually completely sh*gged and needs a new engine fitting.
Where are you based?
Old 19-06-13, 08:13 AM   #5
Littlewebber
I live in poole (dorset) and yeah just took it down the bike shop and he rekons i ****ed top end and reccomends buying new engine as cheaper than fixing this one now on the hunt
Old 19-06-13, 08:17 AM   #6
Expensive lesson. There is no such thing as can't afford oil. What that actually means is "can't afford lunch". Even some 99p a litre crap is better than nothing.
Old 19-06-13, 08:19 AM   #7
Littlewebber
I know it my fault, but i didnt think that a week from near the lower limit would nearly empty it, there was literraly a cup full left when i drained it
Old 19-06-13, 03:00 PM   #8
Skybaba
Ouch; sorry to hear that man!
Good luck with the hunt.
Old 19-06-13, 05:08 PM   #9
SvNewbie
Maybe a small consolation, if it was using that much oil something expensive was possibly wrong with your engine to start with.
Old 19-06-13, 10:29 PM   #10
Phoenix22
This has to be a wind up yeah?
v5 problem maclovin Bikes - Talk & Issues 11 01-07-09 08:54 PM
I have a problem. dirtsk8 Bikes - Talk & Issues 4 06-08-08 12:43 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
FI problem on SK3 - help!!! Keitht SV Talk, Tuning & Tweaking 8 19-04-05 03:56 PM
