Old 25-06-13, 06:26 AM   #1
PyroUK
PyroUK's Avatar
Default Pointy won't start
Ok so got out the house to get bike ready for work, alarm off, key in, turn on. Funny noise from the FI or whatever it is. Clutch in press starter button...nothing, not a peep.
Check kill switch is properly off still nothing, **** around with side stand and nothing.
The priming sound keeps happening but other than that bugger all.
I did adjust my clutch yesterday but don't see anything that could have buggered it as it was working fine!
Checked all the fuses I can find and all ok.
Looks like the button does work as the lights dip when I press it.
Any ideas? Gonna have to get a bloody taxi to work now so will hopefully try them this afternoon
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 25-06-13, 07:57 AM   #2
jambo
jambo's Avatar
Default Re: Pointy won't start
Do you have stubby clutch lever?
The clutch switch can end up not being thrown properly when they're adjusted.
Jambo
Sent from my thingie
Old 25-06-13, 08:06 AM   #3
Owenski
^ This,
Remove the clutch switch connector off the perch and short them 2 terminals see if that fixes your woe
Old 25-06-13, 08:12 AM   #4
PyroUK
PyroUK's Avatar
Thanks guy, I do have stubby ones on there, tried putting the adjuster to the max position but no joy. Where abouts is the switch? I may have knocked it out if place when working out the free play!
Old 25-06-13, 09:34 AM   #5
Owenski
You've got a 2 prong'd connector coming out of the cabling about an inch from the LHS switch gear.
This connects to the 2 terminals pretruding from the underside of your clutch pearch. If they're not connected then there's your problem, of course they may be connected but that still may be your problem lol. HTH
Old 25-06-13, 09:37 AM   #6
PyroUK
PyroUK's Avatar
So on the actual lever holder thing yeah? Would I need to take the lever off to check this?
Thanks!
Old 25-06-13, 09:40 AM   #7
Owenski
Yeah its on the underside, no need to remove anything. Just get down on one knee and take a look underneath, all should make sense then.
Old 25-06-13, 09:41 AM   #8
PyroUK
PyroUK's Avatar
Ah right ok, will take a look when I get home! Thanks!!!!
Old 25-06-13, 02:47 PM   #9
how about you have left it in gear.
Old 25-06-13, 02:48 PM   #10
PyroUK
PyroUK's Avatar
Nope, even took it off the stand to see if that made a difference
Pointy start up display? TheRuffellator SV Talk, Tuning & Tweaking 3 05-05-13 09:16 PM
Pointy won't start. DanSp SV Talk, Tuning & Tweaking 3 28-02-13 10:39 PM
Must be summer, Pointy wouldn't start. munkygunn182 SV Talk, Tuning & Tweaking 10 27-03-12 05:18 PM
Pointy won't start! trinyquist SV Talk, Tuning & Tweaking 19 15-10-08 10:35 PM
Please Help Pointy woes - won't start. RGV250ads SV Talk, Tuning & Tweaking 17 20-05-08 04:28 PM
