Old 25-06-13, 07:26 PM   #1
strop
Default Curvy low beam not working.
I have had a look through search but couldn't really find anything so I thought I would ask if anyone knew of any common problems which would cause the low beam not to work on a 99 curvy,both lights,the parking and high work so assume its just the one wire broken or corroded,any idea where to start looking?switch appears to be ok.
if not anyone know of a good mechanic or auto electrician in the st albans area,thanks for looking any help gratefully recieved
strop is offline   Reply With Quote
Old 25-06-13, 07:34 PM   #2
leebex
Default Re: curvy low beam not working
Had this twice on my pointy recently, the connector plug behind the fairing has been arcing out and burnt the pin on mine.
Had a similar lesser case on my old curvy, worth a look, on a curvy s model its behind the right hand side of the front fairing.
Lee
Old 25-06-13, 07:46 PM   #3
Just to clarify:
1. Both low beams don't work, yes?
2. You have checked both bulbs and the low beam fuse?
Old 25-06-13, 08:27 PM   #4
strop
Default Re: Curvy low beam not working.
yes both bulbs didn't realise the beams were separately fused,duh, will check the fuses in the morning thanks
Curvy headlights not working a_monkey_hint SV Talk, Tuning & Tweaking 25 21-09-13 12:49 PM
Curvy speedo not working. Luke-Mac SV Talk, Tuning & Tweaking 3 19-03-13 08:16 PM
Curvy low beam doesn't work. 01 sv650s SV Talk, Tuning & Tweaking 6 22-10-12 09:40 PM
low beam working intermittently. Dave20046 SV Talk, Tuning & Tweaking 24 30-07-10 11:49 AM
low beam not working. Slash SV Talk, Tuning & Tweaking 3 26-09-08 02:28 PM
