Old 13-07-13, 07:36 PM   #1
JohnStMartin
Default Oil level - check upright or on stand?
its over full when the bike is upright , and just over empty when on the sidestand... whats going on, which reading is OK (pun intended)
Old 13-07-13, 07:46 PM   #2
dkid
Default Re: really stupid oil level question
level is measured with bike upright
Old 13-07-13, 07:47 PM   #3
savage86
Shouldn't be over full when upright. Somewhere in between when upright not on rear paddock stand either.
Old 13-07-13, 08:29 PM   #4
JohnStMartin
ok, its just such a huge difference considering the lean angle on the side stand. will overfill damage the bike?
Old 13-07-13, 09:05 PM   #5
stuR
Officially yes, damaging gaskets and oil seals however alot of people tend to go with a little more is better than not enough.
Old 13-07-13, 09:14 PM   #6
Kwally5
Too much can also be as bad as not enough. If it was me I would undo the sump plug and let a bit out when upright so it sits just under the full mark.
That way you know your safe
Old 13-07-13, 09:19 PM   #7
stuR
If it was me and it was overfilled, i wouldnt touch the sump. No doubt half the oil will spill out, just syringe it from the top will be easier and less messy.
Old 13-07-13, 09:20 PM   #8
dkid
+1
Old 13-07-13, 09:28 PM   #9
Ginja_Joe
I always check the level on rear paddock stand. I haven't found another way that isn't a faff ...
Old 13-07-13, 09:42 PM   #10
jambo
jambo's Avatar
The bike needs to have its oil level checked with both wheels level and the bike upright.
If the bike's on the side stand you put quite a bit more oil in than you should.
If you use a rear paddock stand and no front stand the motor's tilted forwards, you'll under fill with oil.
Jambo
Sent from my thingie
stupid or very stupid that is the question davepreston Bikes - Talk & Issues 29 26-03-10 01:32 PM
stupid question touch107fm SV Talk, Tuning & Tweaking 3 17-09-08 05:55 PM
Ok stupid question aarond SV Talk, Tuning & Tweaking 2 19-05-07 04:47 PM
Stupid question: How do you know..... Rick-UK SV Talk, Tuning & Tweaking 22 20-11-06 09:39 PM
DAS - A stupid question Tiger 55 SV Ecosse 12 15-09-06 12:03 AM
