Old 14-07-13, 12:18 PM   #1
Grant66
Grant66's Avatar
Default Tyre damage - cause?
http://i21.photobucket.com/albums/b2...ps7dcdf38e.jpg
What could have caused this? Is it use damage or a fault in the tyre? Is it dangerous?
Formerly known as Gajjii
Previous Bikes: Red Sk1 Curvy, Red MT-07.
Current Bike: Black MT-09.
Grant66 is offline   Reply With Quote
Old 14-07-13, 03:34 PM   #2
DJ123
DJ123's Avatar
Default Re: Tyre damage
looks like something has caught the sidewall and taken a chunk of rubber out
BMW F800ST
Old 14-07-13, 10:40 PM   #3
stuR
Default Re: Tyre damage - cause?
Total guess, possibly wouldnt affect a motorbike tyre but maybe a big pothole and the side wall has been pinched by the rim? no idea tho, just a punt
Old 15-07-13, 09:05 AM   #4
NTECUK
NTECUK's Avatar
I wouldn't feel confident using it.
Old 15-07-13, 09:08 AM   #5
Dicky Ticker
Yes, and not repairable, needs replacing-----a front wheel blow out is not a nice occurrence.
As you have managed to take a chunk out of the tyre and split the carcase there is most likely damage to the inner tyre wall structure.
MOT failure and a nick for a defective tyre if stopped.
Down to you if you continue to use it or not.
Old 15-07-13, 09:09 AM   #6
Can't imagine what caused that - but that's damage, not a fault.
Old 15-07-13, 09:14 AM   #7
NTECUK
NTECUK's Avatar
Pot holes or kerb bumping.
Old 15-07-13, 12:40 PM   #8
wideguy
There doesn't appear to be any damage to the wheel, which I would expect from a curb/pothole encounter that would strip off a chunk of rubber. This chunk appears to have been ripped off from the wheel side out.
But, there's a lot of pitted and eroded looking areas nearby that are not normal and certainly not the result of abrasion or impact.
I suspect a manufacturing defect, some contaminant in the rubber before they laid it up.
Old 15-07-13, 12:48 PM   #9
SvNewbie
Pure speculation on my part, but could it be that the impact site was at the deep looking cut on the right hand side and the damage to the carcass caused the larger area of damage? Don't think there would be any way to tell without taking off the tyre.
Old 15-07-13, 01:57 PM   #10
Grant66
Grant66's Avatar
My thoughts were that it didn't look like something caused by a pot hole (no rim damage at all) going to get it changed and have them send it back to Avon for assessment. The mark next to the missing rubber is about 0.5 mm deep and could be the caused by a pot hole
Tyre damage advice. Pricey12 Bikes - Talk & Issues 15 14-02-13 03:17 PM
Rear tyre damage? Nobbylad Bikes - Talk & Issues 3 06-08-08 02:41 PM
Advice please- tyre damage DMC Bikes - Talk & Issues 9 21-07-08 11:03 AM
Tyre damage again !!! Question steveg SV Talk, Tuning & Tweaking 3 08-02-08 03:22 PM
Damage running deflated tyre Alpinestarhero Bikes - Talk & Issues 2 16-08-07 01:00 PM
