Old 19-07-13, 02:55 PM   #1
cornishsv
Default Used tyres - yes or no?
What peoples views on using part worn tyres? I'm a bit strapped for cash at the moment and need to replace the front tyre on the sv but been offered a part worn of the same make as the one on the bike with about 3mm tread for £20 and im tempted
Old 19-07-13, 03:32 PM   #2
Default Re: used tyres
if your strapped for cash go for it but add another £10+ for fitting.
Old 19-07-13, 04:31 PM   #3
Nutsinatin
Nutsinatin's Avatar
As Bibio said it's about £10 to have it fitted, then £10 to get another tyre fitted again soon when this one goes, so a new tyre is better but this will do the job better than your current one for now.
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 19-07-13, 05:10 PM   #4
Fallout
Fallout's Avatar
As long as it wasn't removed from the previous bike because it was old. Re: the coach crash on TV recently. A tyre can look fine but be lethal if the rubber has dried out (or whatever chemical process occurs over time).
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 19-07-13, 08:03 PM   #5
Pete7
Pete7's Avatar
Modern tires have a date code moulded into them. I had to change out a trials bike front which was from 1993
3mm for use during the summer, I probably would use it too.
Pete
It's official, the iconic naked curvy SV650 are now classics
Pete7 is offline   Reply With Quote
Old 20-07-13, 03:34 AM   #6
Serdna
Default Re: Used tyres - yes or no?
I started changing my own tyres, then buying part worns becomes cost effective.
http://www.youtube.com/watch?v=anyY0UO5gqk
http://www.youtube.com/watch?v=UPaCV_uCi78
The first guy has the better method but he is a bit OCD about his disks. I havent felt the need to take mine off. The spade trick for breaking the bead works surprisingly well, and if you have a thin piece of wood between the rim and spade you would have to be pretty special to do any damage.
Its worth considering doing for anyone on a tight budget.
Old 22-07-13, 08:29 AM   #7
Steve_God
I used ex-race worns before with loads of tread on before absolutely fine.
Just make sure you're aware of what type of tyre is it (eg, for racing, touring, etc...) as my only issue with them was around the actual compound of the rubber being supersoft for the track, and therefore took considerably longer than standard road tyres to get heat into them before they would grip well.
Bike Tyres Leeds - free fitting on Michelin Tyres through Feb & March Paul the 6th Pennine Massive 14 03-03-12 04:59 PM
What Tyres To Put On? Sticky Tyres. SV650R Bikes - Talk & Issues 33 22-10-09 01:50 AM
Tyres again! New tyres to replace stock ones metalmonkey SV Talk, Tuning & Tweaking 12 01-07-08 05:48 AM
Tyres you have... tyres you gettin'? Daz TOTALSV Ireland 6 04-02-05 10:34 PM
Tyres oh tiring tyres 454697819 SV Talk, Tuning & Tweaking 15 13-10-04 08:40 PM
