Old 19-07-13, 05:23 PM   #1
ruddlad
Default could disc lock bend forks?
to add to my previous disc lock mishap
can you bend the forks?
only asking as it is leaking on same side now
was literally 2mph and barely moved but took speedo drive out
replaced that but on tuesday there was oil from the dust cover dripping down.
guessing the heat (hopefully) has just sped up an existing weak seal and is a coincidence.
have seals and oil ready to do
Heaven won't have me, hell's afraid I'll take over
ruddlad is offline   Reply With Quote
Old 19-07-13, 05:57 PM   #2
stuR
Default Re: could disc lock bend forks?
Dont change the seals before trying a seal mate...saves u a job!
Old 19-07-13, 06:02 PM   #3
ruddlad
is that the plastic strip you fish around with?
also likelyhood of bending forks with lock??
Old 19-07-13, 06:07 PM   #4
stuR
Yup to remove any grime making it unseal. I was skeptical but ive tried it on one minor leak and one big leak and it works. Hm, not sure. You rolled the bike off the stand then it hit the lock? Well, i doubt the lock or disc would have been bent much, so the fork probably took the brunt, but im no expect.
Old 19-07-13, 06:15 PM   #5
ruddlad
was 8 days later it leaked. not an sv, on side stand bike barely moved.
brake caliper would have took the force and thats fine.
didnt know how easy/hard forks bend and how much to cauae a leak
Old 19-07-13, 06:29 PM   #6
Tomor
Tomor's Avatar
I think hitting a pothole puts more force on the forks than a disc lock would just rolling it forward. For that reason, I doubt it is related.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 19-07-13, 07:00 PM   #7
Fallout
Fallout's Avatar
Agree with Tomor. The shocks take a hell of a beating when you're hitting ruts at 100mph. Don't think a disc lock could possibly bend it at really low speed. Would it not have hit the brake calliper first anyway?
Edit: @Tomor - How much did hitting a bambi at 50 bend your forks?
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 19-07-13, 07:10 PM   #8
ruddlad
yeah did just that fallout, hit calliper and broke speedo. speed was walking and went inches. no noises just no movement
hopefully coincidence but is leaking and pooling on same side.
Old 19-07-13, 07:12 PM   #9
Tomor
Tomor's Avatar
Not enough to write them off, motoliner straightened them.
Which disc lock? KobayashiMaru Bikes - Talk & Issues 11 28-04-13 09:42 AM
Which disc lock? GIZZY66 Bikes - Talk & Issues 11 17-12-11 10:03 PM
Which Alarmed disc lock? sauluk Bikes - Talk & Issues 23 18-01-09 07:45 PM
FREE (ish) disc lock hovis Idle Banter 9 23-11-06 01:43 PM
Disc lock and chain copper kettle Bikes - Talk & Issues 6 06-09-05 10:27 PM
