Old 30-07-13, 03:36 PM   #1
Mark-SV-UK
Default Front and Rear Sprocket sizes (Pointy 09) Fully Faired?
I was looking at one of the tables someone on here made for sprocket sizes and had a play around with diff sizes front and back and found a place that will supply chain and 17 front 39 rear supposedly changes top end to 182mph lol would this be possible or would it be a waste of time?? would I loose acceleration or would bike just ride like poo!
Your thoughts please guys and girls, be nice please im new to all this tweaking ect and just want opinions and best combinations you are using.
Mark
Old 30-07-13, 03:45 PM   #2
Default Re: Front and Rear Sprocket sizes (Pointy 09) Fully Faired
with those sprockets you wont get to top out and be slow as feck from the off. if you want fun go up a few on the rear, you'll still hit 120 but much quicker.
Old 30-07-13, 03:47 PM   #3
Mark-SV-UK
Thanks mate all this info helps me learn about my bike
Old 30-07-13, 03:47 PM   #4
jambo
jambo's Avatar
With standard gearing the bike probably runs out of power before hitting the limiter in 6th.
This happens because the power that the engine can produce is not enough to overcome the air resistance and other drag forces, raising the gearing would mean that this would happen at a lower rpm, and probably a lower road speed too.
Sadly there's more to making a bike crack 200mph than selecting the right renthal sprockets
Lowering gearing will give the bike more acceleration but make it sit at higher rpm for a given gear and road speed which can be annoying on the motorway. Raising it will make it more relaxed and economical on the motorway at expense of acceleration.
There are advocates of changing it either way depending on your preference for the right way for the bike to feel
Jambo
Old 30-07-13, 03:52 PM   #5
Mark-SV-UK
thanks also Jimbo every little bit of advise helps.
What are you both running on sprockets Guys ??????
Old 30-07-13, 06:19 PM   #6
aesmith
Default Re: Front and Rear Sprocket sizes (Pointy 09) Fully Faired?
My fully faired K6 is running 15/45. It should be 15/44 according to the book.
Old 30-07-13, 08:10 PM   #7
Tomor
Tomor's Avatar
When I got my SV, it was, unknow to me, running 4 teeth up on the rear. Made acceleration very quick
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 30-07-13, 08:56 PM   #8
Mark-SV-UK
I bet it did lol
Old 01-08-13, 10:43 AM   #9
nikon70
this is actually quite interesting, as I am getting pants mpg on the motorway at the moment, mind you I do pelt it up the m1
If I had the time and money I would swap the chain & sprok depending when I am going but that's just too much of a faf...
I might go up a few teeth on the rear and down one or two on the front when I change the chain....
good read
Old 01-08-13, 10:50 AM   #10
granty92
this is interesting as im running 15/45, thus making acceleration a bit quicker?
Sprocket sizes, Pointy S? granty92 SV Talk, Tuning & Tweaking 18 04-08-12 07:43 AM
K3 650 fully faired gsxr front end £1300 widget For Sale - SV's and SV related items 22 01-02-12 04:11 PM
sv650s fully faired k3 gsxr front end widget For Sale - SV's and SV related items 15 16-09-11 09:50 AM
Looking for fully faired pointy Maruchino Stuff Wanted 0 26-07-09 05:50 PM
