Old 03-08-13, 05:43 PM   #1
rs2fifty
Default Torx bolts to remove ignition barrel?
I am replacing my clipons with a yoke conversion and need to get hold of the special torx like tool to undo my ignition barrel, does anyone know where i can get one or are they a suzuki only tool i have to get from them?
Thanks
Old 03-08-13, 05:49 PM   #2
stuR
Default Re: Torx bolts to remove ignition barrel?
Is it a security torx like this?
http://www.google.co.uk/imgres?imgur...7Q-f6-Q5XyM%3A
Cuz if so halfords sell em. I thought with some barrels you need to grind/cut off some rivets too iirc?
Old 03-08-13, 05:49 PM   #3
Pretty common things. Think it's T40 if I remember right. You can get them on ebay
Old 03-08-13, 05:53 PM   #4
rs2fifty
Thats what it looks like, i will try halfords first then
Cheers guys
Old 03-08-13, 05:59 PM   #5
tiz a security 6 point T40. you need the hole in the middle.
Old 03-08-13, 05:59 PM   #6
If not screwfix do them
Old 03-08-13, 06:00 PM   #7
They will probably be a ******* to get out, as Mr Suzuki, he use a lot of thread lock on them
Old 03-08-13, 06:02 PM   #8
ooohhh and turn the yoke over on the forks so the bolt is facing you then before you try and take it off put a good and hot soldering iron on the bolt for a good 5 mins to soften the threadlock.
Old 03-08-13, 06:10 PM   #9
+1
Old 03-08-13, 06:38 PM   #10
rs2fifty
Brilliant, thanks guys
Replacement Bolts for Ignition Barrel? slloyd SV Talk, Tuning & Tweaking 27 30-04-13 11:52 PM
Ignition barrel shear bolts and solder help _Stretchie_ Bikes - Talk & Issues 8 05-07-12 08:52 AM
ignition security torx size? davepreston Bikes - Talk & Issues 7 01-05-12 07:14 PM
What tool to remove ignition bolts? (Pin-Trx???) FreshAL SV Talk, Tuning & Tweaking 7 20-07-07 07:36 AM
Ignition barrel for a K2 Mervin Stuff Wanted 0 03-01-06 04:29 PM
