Old 05-08-13, 11:05 AM   #1
daveyrach
Default Where do the crank case breathers connect?
So took my air box off to get to my throttle cables and in doing so dislodged a hose which I now know is the crankcase breather hose.
I cannot for love nor money find the connection on the crank case, can anyone shed some light on it for me?
Old 05-08-13, 11:10 AM   #2
jambo
jambo's Avatar
Default Re: Where the hell is the connection for the crank case breather?
There are 2.
The one that usually gets dislodged it right at the back of the motor, over the gearbox. You''ll want a torch...
The other's on the front cylinder base.
Here's a picture of a motor with the breathers attached:
Jambo
Old 05-08-13, 01:02 PM   #3
daveyrach
Yeah the front on is fine and in place, how do i get to the rear, it seems to be hidden behind the frame. It will be an issue running with it off though won't it.
Old 05-08-13, 01:08 PM   #4
jambo
jambo's Avatar
The motor will run fine, you'll draw some road crud into the engine and coat the back of the bike including the rear tyre and shock in oil.
So it's not, like, plan A...
Take the tube off the airbox to give you the most working space, you may even find getting your hand in from the swing-arm side helps. Know any 5 year olds with bendy fingers?
Jambo
Old 05-08-13, 01:14 PM   #5
daveyrach
I have a 3 1/2 year old daughter who likes to 'help' me in the garage, not sure her mum would appreciate it.
I will have to have another look as it looks like the battery box prevents access from the rear and stops oil going over the tyre, unless I drop the whole undertray out which involves taking out the battery.
Old 05-08-13, 06:12 PM   #6
It's fiddly, but you can refit the hose without too much dismantling
Old 05-08-13, 06:22 PM   #7
daveyrach
Default Re: Re: Where do the crank case breathers connect?
It was fiddly. Managed to do it by lifting the tank.
Sent from my Galaxy S2 using Tapatalk
Carb Breathers -Ralph- Bikes - Talk & Issues 10 02-06-11 01:40 PM
Crank case differences? Chappyr1 SV Talk, Tuning & Tweaking 2 16-02-11 12:29 PM
RHS crank case chakraist Stuff Wanted 2 29-08-09 05:43 PM
Engine breathers yorkie_chris SV Talk, Tuning & Tweaking 10 05-06-09 06:27 PM
head breathers antony SV Talk, Tuning & Tweaking 2 06-02-08 02:08 AM
