Old 07-08-13, 08:56 AM   #1
mase_tw
Default Problem fitting R6 race fairings.
Hi,
Well i got my originals off my bike last night with a help from a few friends and ive gone to put the new race ones on and cant seem to find where the front nose cone mounts up to?!?!?!
Also i have to order DZUS fasteners as it has the clips on the back already moulded into the fairing.
Does anyone know a good place to order them from? need about 15.
Any help would be much appreciated as i hate not finishing a job!!
Mason
Old 07-08-13, 09:40 AM   #2
mase_tw
Default Re: Stuck Fitting R6 Fairings!!
Are these the correct ones i need?
Old 08-08-13, 02:07 PM   #3
mase_tw
Default Re: Problem fitting R6 race fairings.
Also do i need aftermarket brackets for the front nose cone?
Old 08-08-13, 03:57 PM   #4
jambo
jambo's Avatar
If you have any way of finding who made this set of fairings that'll help your search. Loads of companies make after-market fairings for bikes. Some bolt straight to the existing subframes, so assume you'll use one of their race subframes. Without knowing who made yours you may need to fabricate something.
Jambo
Old 08-08-13, 05:03 PM   #5
Redmist
The DZUS fasteners come in different lengths dependent on how thick the joins in the fairings are etc etc.
Have a guestimate and then order based on that.
You can re-work the original front subframes removing bits / adding ally strips as required. The aftermarket ones are so much easier to work with tho, due to using softer aluminium not steel. Pricey tho!
Fitting BB plastics Fairings davegixer1300r Mini-Twins 19 18-07-12 03:06 PM
Pointy model gsxr k6 race fairings, seat unit and fairings bracket sv650k4 For Sale - SV's and SV related items 0 08-07-11 02:16 PM
re-fitting the fairings badsaboy SV Talk, Tuning & Tweaking 4 26-05-10 02:22 PM
Help - fitting lower head race bearing problem maviczap SV Talk, Tuning & Tweaking 14 08-02-10 10:49 PM
Help with fitting gsxr1000 k5 race fairings to a K4 SVS sv650k4 Mini-Twins 4 20-12-07 03:41 PM
