Old 18-08-13, 07:37 PM   #1
chris SVK3
Default Which suspension improvements? Pointy.
Hi,
I am looking at returning to sv650 after not owning one for the last 8 years. I have been riding zx6r, vstrom and street triple r but unfortunately I was involved in accident in July that written off the street triple and broke most of the right side of my upper body. Therefore the wife isn't to happy with me road riding any more as this accident was due to someone pulling out me.
So I have decided to buy a used sv650s for which I want to use for both track and limited road use. ( still to do alps in summer with the lads).
On my old sv650s K3 I changed the shock for a Suzuki GSXR K3 one and the front spring to max ton and changed the fork oil both made a major improvment. So what I'm looking for now is what are the best improvement for track use for 13 st rider in kit which wouldn't back it a pig on the road.
I have looked a fork conversion and zx6 shock but not sure of years as I would want to be a straight fit. Also money is tight so I don't want spend a fortune if the improvements aren't massive.
Thank you for your help?
Old 18-08-13, 09:31 PM   #2
Tomor
Tomor's Avatar
Default Re: Back to an sv650
Welcome back (should I be saying that with not riding an sv n all that?)
Info on shock HERE
Forks I cant help with, as I just put some thicker oil in as there were already new springs in there (albeit upside down!!)
Tom
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 19-08-13, 08:26 AM   #3
chris SVK3
Default Re: Which suspension improvements?
That's great thank you, I take it I can fit any of those shocks so it just a case of finding the best condition one.
Old 19-08-13, 08:58 AM   #4
johnnyrod
johnnyrod's Avatar
At the front, stiffer springs and oil are the best VFM. I also went for emulators, which are good on the road but to be honest if you ride like your backside is on fire on the track, I'm still not amazingly happy with the front end. If you envisage that sort of thing (and you already know what the SV feels like with the springs/oil) then I'd go for the GSXR front end, maybe do it over winter if you have the option. Obviously mroe money but then if you spend money now on the forks and wanted to change later it'd be even more so worth thinking about - it's not like it's unrideable in stock form.
Old 19-08-13, 09:10 AM   #5
chris SVK3
Thanks which gsxr forks go straight on the point sv?
Old 19-08-13, 09:30 AM   #6
Entire K1-3 front end goes in piece of p*ss
Old 19-08-13, 12:01 PM   #7
johnnyrod
johnnyrod's Avatar
Default Re: Which suspension improvements? Pointy.
Do a search, loads of info on here. yes very easy on a pointy, same headstock bearings etc. I believe.
Old 19-08-13, 12:13 PM   #8
mikerj
There are no decent forks that are a direct swap AFAIK. To fit the forks from a GSXR etc you need to change the yokes, forks, front wheel, brakes etc.
A set of emulators plus suitably rated springs will make a significant improvement to the standard forks however, and is a much cheaper and simpler job.
Old 19-08-13, 12:27 PM   #9
my brain might not be working but IIR the Honda CBR-F 600 F3 fork stanchions and cartridges fit in the SV tubes with very little modification and allow you to keep the yokes etc.etc from the SV.
Old 19-08-13, 12:29 PM   #10
Yeah they do, but personally for a track bike I would want the comp adjusters.
You can make this happen on the CBR cartridges but it's not easy or conventional!
Curvy suspension improvements? Bigsuze650 Bikes - Talk & Issues 1 03-06-13 02:40 PM
Curvy suspension improvements? loonytoon SV Talk, Tuning & Tweaking 12 14-11-12 09:53 AM
Upgrading the suspension on a pointy dual-power sv SV Talk, Tuning & Tweaking 35 04-02-09 04:49 AM
Suspension advice pointy. ScottishRawker SV Talk, Tuning & Tweaking 10 24-04-08 12:21 AM
front suspension 03 pointy medwaysv SV Talk, Tuning & Tweaking 2 06-06-06 06:54 PM
