Old 23-09-13, 03:12 PM   #1
Penry
Default K6 SV650 non runner after 3 months storage.
Hi, after having the motorcycle sat for 2-3 months unexpectedly it doesn't seem to fire up to well/not at all.
The tank was drained and the lines were, battery was put on charge on the day and it sounds like it wants to tick over -- struggles and just about fires up then cuts out instantly.
To me it sounds like fuel starvation, however the tank is full of new petrol when trying and I pumped the throttle a little bit before trying to fire it up with the ignition on.
Old 23-09-13, 04:29 PM   #2
jambo
jambo's Avatar
Default Re: 2006 SV650 Problem!
OK,
1) For 2006 The bike is injected. When you turn the ignition on do you hear the fuel pump whine up and then stop?
2) Opening and closing the throttle with engine off will make no difference to moving fuel on this bike
3) Do you get any error messages on the dash when it is running or before it starts?
4) Did it work perfectly before being laid up?
5) Is it turning over strongly or only just managing to turn?
Jambo
Old 24-09-13, 01:05 PM   #3
agent wayward
Default Re: K6 SV650 non runner after 3 months storage.
Check that the fuel line and all other connections to the tank are seated correctly.
That's the thing that you disturbed; before then it was running fine, so that is the most likely candidate.
Old 25-09-13, 12:11 PM   #4
jewkc
if all else fails get someone to help you bump it (2nd gear and a good hill does come in handy), sometimes they need a bit of a hand if it works bike should be fine to start after a good run.
Old 25-09-13, 03:04 PM   #5
aesmith
Mine (also a K6) had a bit of a sulk after sitting for a couple of weeks. Try full throttle while cranking .. that's what brought mine to life in the end. I have a suspicion that the fast idle was sticking and not setting properly.
2006 (56) SV650 SK6 For Sale SV Mad For Sale - SV's and SV related items 10 25-06-12 05:38 AM
For Sale: 2006 SV650 SK6 baz8481 For Sale - SV's and SV related items 1 28-04-10 07:32 PM
2006 Suzuki SV650 S K6 connect4king For Sale - SV's and SV related items 2 18-06-09 12:13 PM
2006 Sv650-s david-m For Sale - SV's and SV related items 1 28-05-08 06:23 PM
Just bought a new 2006 SV650 ohiobiker SV Talk, Tuning & Tweaking 2 24-04-06 12:11 PM
