Old 01-10-13, 10:01 PM   #1
apchara
Default Curvy misfire/splutter at 7500 rpm.
hi there guys firstly HEEEELLLLOOOOOOO, i love a good forum makes like so easy, you get to meet some standup chaps on these "enthusiast" forums!!
I recently bought a SV650s, on a Y plate(99?)*Being a young(ish) lad of 25 its all injection and sensors and computers, carbs are a new world to me
As for the bike i bought it for £470 as a non runner from a guy who would just chuck it in the garage whenever anything needed doing, he wasnt a "have-a-go-hero" so everything is above board, the bike had been sitting for 10 months open street in Paddington, no cover, so there was water and crap going in everywhere after some research I have flushed carbs and got virtually all the water and gunk out, flushed tank too, new plugs fitted, also going to be doing an oil change with filter and air filter this weekend and new water/coolant. It does not rev past 7.5k without a good splutter?!?! I ran it airboxless to get it home as filter was too wet to let a proper flow through. i noticed one crank breather blows more than anotheralso Both manifolds warm up so i doubt its a misfire. i managed to ride it home to walthamstow, being carbs im a tad clueless, i know HOW they work and whats what but as for stripping i dare not until ive been told that is HAS to be done. i really enjoyed the ride back on the SV it's a VERY VERY different feel to the XJ6 i'm using at the moment, i love the torque and the light handling of the SV!
any ideas on solving the splutter at 7.5?
Old 01-10-13, 11:21 PM   #2
wideguy
Default Re: Curvy misfire/splutter at 7500 rpm.
Does it do this with the airbox and filter installed?
Old 02-10-13, 06:17 AM   #3
apchara
ill fog out n abut 12 hours, will put new filter in and give it a whirl, it didnt run with the airbox on
whats the difference between curvy and pointy?
Old 02-10-13, 06:38 AM   #4
Mauler
Mauler's Avatar
Horrible styling on the pointy with an injected engine and fancy dash.
Real techical info I'll leave to someone who is a bit more familiar with pointies than I am...
"If more of us valued food and cheer and song above hoarded gold, it would be a merrier world."
-Thorin Oakenshield, The Hobbit
Mauler is offline   Reply With Quote
Old 02-10-13, 09:24 AM   #5
atassiedevil
Sounds like fuel starvation at higher revs. Partially blocked main jet, bent needle, etc?
Could just be the lack of filter too. Get that back in to start, and we'll see where we go from there.
Choke plungers are known to stick in various positions and cause issues too. Does the problem go away wtih the choke on full?
Old 02-10-13, 09:43 AM   #6
Also make sure carb rubbers are properly seated in the airbox
Old 02-10-13, 04:13 PM   #7
apchara
So pointys are **** and modern and do everything better than a curvy!! Got it!!
Goiing to carb cleaner tonigh are the choke plungers the big black things over the needles?
The front carb rubber is a pain to fit but I have the tools to get it on, will try full throttle with choke on once the box and new filter is fitted
Old 02-10-13, 05:04 PM   #8
Biker Biggles
Biker Biggles's Avatar
The choke plungers are the bits that go into the sides of the carbs at the end of the choke cables.Held in by a plate with a screw through it which can be difficult to get off.A very common cause of poor running so need unsticking regularly.
Old 03-10-13, 12:36 AM   #9
apchara
SHE LIVESSSSSSS
hence the late post, stripped carbs, flushed float bowls new air filter refited airbox (nicelly), greased the front plug lead seal, wiped down most of the MUNK (mud, soil, dust, grease and other road crud)
OMGGGGG what a ride!!!! she pulls like a dream and can just go and go and go
now to strip, proper clean, respray, replace the seat and repair some fairing cracks!
Old 05-10-13, 01:05 AM   #10
apchara
So....... had an awesome 5 hours out and about, met a few guys from here up frith street on the way home, lost all power, bike rides and idles fine but all the oomph has gone, it revs ok but under load it does nothing! !
Ideas?
Misfire on cold start - Curvy. shane1964 SV Talk, Tuning & Tweaking 11 14-10-13 06:40 PM
Curvy intermittent misfire. chuck43 SV Talk, Tuning & Tweaking 15 22-04-12 03:11 PM
Curvy SV650SX misfire from 5000rpm ianhaigh SV Talk, Tuning & Tweaking 3 07-06-10 07:36 PM
Curvy misfire. mike_red2uk SV Talk, Tuning & Tweaking 16 08-05-10 05:47 PM
7500 mile Service on a curvy (K1) jamieb SV Talk, Tuning & Tweaking 5 05-08-05 03:31 PM
