Old 03-10-13, 05:49 PM   #1
Tommo1988
Default Removing a clip on?
To replace a bent clip on!!! Small jobs r so flamin hard to do!
Old 03-10-13, 06:09 PM   #2
Default Re: Why isnt ther a easy way!!
it's only as hard as you make it. TBH it's a pretty simple job and should only take a max of 10mins unless you are not used to tools.
Old 03-10-13, 06:16 PM   #3
Tommo1988
The fastest way I can think of doin it is to drop the forks through the top yoke. Simply because I can't get to the ignition barrel T40s. What ya think?
Old 03-10-13, 06:22 PM   #4
daveyrach
Just take off stem nut and remove top yoke. Simples.
Sent from my Galaxy S2 using Tapatalk
Old 03-10-13, 06:23 PM   #5
nope, take the yoke top nut off and move the yoke out the way. there is enough slack in the ignition cable.
Old 03-10-13, 06:33 PM   #6
Tommo1988
I took the center nut off then loosened off the two nuts on either side but it didn't budge :s
Old 03-10-13, 06:37 PM   #7
Tommo1988
Ur right just had another pop, I love you guys cheers.
Old 03-10-13, 06:41 PM   #8
The steering lock won't easily go past* the frame lug in the same axis at the stem - this is deliberate - it makes dismantling the steering harder and thus makes nicking your bike slightly less simple.
If you want the yoke off you'll need to drop the forks, to replace the handlebar take the front wheel and mudguard off, then slide the relevant fork downwards.
* I have seen it hammered past - don't.
Old 03-10-13, 07:18 PM   #9
Tommo1988
Default Re: Removing a clip on?
No all is good Iv got the new clip on on LOL but now I'm tryin to figure out how to assemble the two throttle cables back onto the throttle tube Lmao epic times.
Old 03-10-13, 07:35 PM   #10
why did you separate them in the first place..... you only need to loosen enough to slide off the bar that is unless you have taken them off the bar before you took the bar off...
What are clip ons? Bordtea Bikes - Talk & Issues 5 05-06-12 09:57 PM
Removing a clip on - how? Lego Bikes - Talk & Issues 4 23-07-09 09:03 PM
Clip ons Taylor1975 SV Talk, Tuning & Tweaking 3 24-03-08 02:39 PM
Clip-ons....(from flat bars to clip-ons) Gnome SV Talk, Tuning & Tweaking 6 12-07-07 06:57 PM
LH clip on ivantate Stuff Wanted 0 03-08-06 06:33 AM
