Old 12-10-13, 07:04 PM   #1
Dalerst
Default Holding the tank up? SV650.
Need to changer the plugs as part of the service not sure when they where last done, lifted the tank earlier today expecting to find a locking pin to hold the tank up! can anyone tell me if there is one or do I need to take the tank off? also if anyone knows the best way to get the the front that would be good as well.
Old 12-10-13, 07:18 PM   #2
Shawthing
Shawthing's Avatar
Default Re: Changing the spark plugs SV650
There should be a tank prop stick under the pillion seat, unless a previous owner binned it.
Releasing the bottom of the radiator and propping forward,e.g. with piece of wood, gives just enough acces for the front plug.
SK9 Sport Black Delkevic can.
Old 12-10-13, 07:26 PM   #3
Dalerst
Thanks the last owner has binned it then the tool kit is also missing, will I have room to do the front with a standard plug socket?
Old 12-10-13, 07:40 PM   #4
Shawthing
Shawthing's Avatar
Youll have to find something else to prop your tank up with , I had same issue and use a fisshing pole rest which is just the right length.
Depends on your tools. The plug is quite a long way down so youl likely need an extension piece between socket and ratchet.
Old 12-10-13, 08:16 PM   #5
Ninthbike
Did mine this afternoon. With the plug spanner from the tool kit it's a piece of cake. I also had to use something else to prop the tank but it's actually a very easy job and took about 20 minutes.
Old 13-10-13, 04:59 PM   #6
MJC-DEV
MJC-DEV's Avatar
The tool kit is under the LH panel down low not under the seat. I thought I didn't have a tool kit for a long while until I found it one day. (press black button to open)
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 13-10-13, 05:13 PM   #7
Dalerst
?? any pics to show where
Old 13-10-13, 09:23 PM   #8
Shawthing
Shawthing's Avatar
Old 14-10-13, 07:40 AM   #9
Dalerst
Thanks I will be checking latter.
SV650 Pointy Bagster tank cover and tank bag Wildkid For Sale - SV's and SV related items 14 14-05-13 09:44 AM
sv650 2000 plate not holding charge horsey Bikes - Talk & Issues 5 17-11-12 01:26 PM
sv650 k3 tank cover, tank bag, left foot peg kiggles Stuff Wanted 0 25-06-10 10:32 PM
Curvy SV650 tank cover with tank bag mounts Paul M For Sale - SV's and SV related items 1 01-10-07 12:16 AM
