Old 23-11-13, 10:26 PM   #1
scotty217
Default ignition switch contacts, svk6
Long story short, Suzi was completely dead today when I put the key in the lock to start her. No lights, no clicks, no fuel pump - completely dead. After all sorts of tests and a couple of phone calls for advice, as a last resort I brushed some IPA into the ignition switch to try and clean the contacts - which worked a treat!
Is there anything I can use to lube and keep the contacts in the ignition barrel sweet, or will IPA be OK in the long term? WD 40 just seems to attract crap, it certainly didn't solve the problem earlier in the day.
Thanks in advance
Scotty
Old 23-11-13, 10:29 PM   #2
Red ones
Red ones's Avatar
IPA?
I've only got Newcastle Brown in my shed. Do you think a drop of Dog will have the same effect?
Old 23-11-13, 11:24 PM   #3
scotty217
Default Re: ignition switch contacts, svk6
Iso Propyl Alcohol
Old 24-11-13, 04:53 AM   #4
Red ones
Red ones's Avatar
Aaahhhhhh!
Old 24-11-13, 02:31 PM   #5
sputnik
Dry graphite lock lube is your friend. Maplin do little squirty cans for £3 if you have one nearby.
Old 26-11-13, 10:52 PM   #6
scotty217
Thanks sputnik I'll give that a try
Scotty
4 wire ignition switch jaymee Stuff Wanted 0 28-05-10 04:14 PM
K9 ignition switch on K5 - C42 code. bikerimp SV Talk, Tuning & Tweaking 0 24-05-10 08:00 AM
k5 ignition switch removal twonky SV Talk, Tuning & Tweaking 3 17-07-08 08:41 AM
Ignition Switch Tris SV Talk, Tuning & Tweaking 0 12-04-06 11:24 AM
Ignition switch compatability kern0079 SV Talk, Tuning & Tweaking 1 11-07-05 10:36 PM
