Old 30-11-13, 11:36 AM   #1
anonbeep
Default anonbeep - Newby introduction
Hello everybody. I am newby anonbeep. I am 68 years old and just bought an sv650 Suzuki and now looking for some advice on everything biking. It is my first bike for 40 years!! First problem, I am five foot three and need to lower it cos can only just touch the ground. Also like to contact other bikers now in South Dorset. Nice to meet you all, beepsy.
Old 30-11-13, 12:55 PM   #2
Redmist
Default Re: anonbeep - Newby introduction
Welcome, you can either get replacement links for the rear suspension to lower the back end or find a lowered seat.
Good luck with it.
Old 30-11-13, 02:01 PM   #3
anonbeep
Good luck with it.
Hi Red. Thanks for that. Now I a real shortass. So what about doing both. I really got a drop this bike as in my inside leg is 26ins. How complicated is it? Is it a done thing to drop both and what is the max I likely to get, if u kno those things. Beepsy
Old 30-11-13, 02:14 PM   #4
Redmist
With the links you can get -40mm at the back end, I've no idea about how much more a lower seat will do. Probably an inch or two more.
What year bike is it?
For replacing the links you need a way of supporting the back end of the bike which doesn't use the swing arm.
As when you remove the links the swing arm goes all floppy!! But other than that there are just two bolts to undo, very easy.
An abba stand or ratchet straps around a roof joist are just some ways of doing that.
Old 30-11-13, 02:19 PM   #5
anonbeep
The bike is a 2000 Wreg sv650s. Whatever that is. Bought it on a whim from my friends girlfriend who has bought a brand new Triumph from Fowlers. It is well looked after 19,000 miles one owner job, new chain and sprockets. They did that. Family are bikers. Sorry I so slow not very good at this yet.
Old 30-11-13, 02:27 PM   #6
Redmist
If it were me I'd try the seat first so that you don't affect the workings of the suspension
For example this seat would fit:
http://www.ebay.co.uk/itm/Suzuki-SV6...item1c398c900a
Then if thats still not enough try a set of these, other ones are available with less reduction i.e. 20mm lower, search around:
http://www.ebay.co.uk/itm/Suzuki-SV6...item1c34083142
Old 30-11-13, 03:20 PM   #7
How doo!
Sent from my ST25i using Tapatalk 2
Old 30-11-13, 04:23 PM   #8
Geodude
Geodude's Avatar
Ahoy and welcome aboard beepsy ride safe have fun
Old 30-11-13, 04:29 PM   #9
Hello and welcome
You should speak to Bibio on here. I think he has done both
Old 30-11-13, 04:37 PM   #10
Default Re: Re: anonbeep - Newby introduction
Hello and welcome
He has!
The shock is a custom nitron unit which doesn't impact linkage ratio
Hi all - Newby Jake.L Idle Banter 6 15-02-12 09:25 PM
Newby madmaxlp2002 Bikes - Talk & Issues 22 19-04-11 05:13 PM
newby saying hi leebex Idle Banter 14 15-04-09 05:29 PM
not quite a newby AlanB Idle Banter 7 14-03-07 10:25 PM
Newby Pilotdom Idle Banter 22 07-12-06 06:57 PM
