Old 02-12-13, 02:32 PM   #1
gt900uk
Default Pointy lower fairing pictures?
Any one got some pictures of their bike showing where the lowers butt up against the nose fairing? Particularly around the front edge. I'm not convinced mine all lines up properly and I can for the life of me see how the c brackets on the radiator line up with the front mounting points as they don't come anywhere near matching up. Starting to wonder if something is bent somewhere.
Old 02-12-13, 05:52 PM   #2
JulesW
JulesW's Avatar
Default Re: Pointy Lower Fairings
Hope this helps
Bikes I've owned and loved:
Bridgestone 90, Honda CB175, Suzuki GT250, Yamaha YZ125, RD350LC x2, RD350YPVS x2 & FZR600, Honda CB900F, Suzuki SV650S K6, 2014 Triumph Street Triple R
JulesW is offline   Reply With Quote
Old 02-12-13, 06:24 PM   #3
gt900uk
Thanks, gives a good idea but do you have anything closer so I could see how the panels line up and what the gap looks like.
Old 02-12-13, 09:12 PM   #4
fizzwheel
fizzwheel's Avatar
Default Re: Pointy lower fairing pictures?
Moved to SV Talk
Old 03-12-13, 03:11 PM   #5
gt900uk
Found some via google image search. Let's me see how it should line up. Still don't see anyway of getting the radiator holes to line up with the front mount holes though.
Old 03-12-13, 07:13 PM   #6
Shawthing
Shawthing's Avatar
The C bracket hole centers are off center to each other so you have to rotate the bracket until all holes/threads lin eup then tighten onto radiator before attaching to lower fairing.
Are you sure you don't have SV1000 lower fairings?
SK9 Sport Black Delkevic can.
Old 03-12-13, 07:46 PM   #7
gt900uk
Thanks those pictures are great. I have no idea to be honest. The fairings came with the bike but were not on it when I bought it. How would I know? One of the c brackets look like yours and the other looks like its been all twisted to make it fit. I am pretty sure that the bike has been on its side at some point with some of the things I have found but the rad looks good and seems to be sitting in the correct place.
Old 04-12-13, 10:47 AM   #8
gt900uk
This is what I have. Managed to get the left side close to being lined up but appears to be missing the spacer that goes through the rubber grommet and needs a little bit of tweaking. It looks like the rad is a bit damaged and perhaps not sitting quite where it normally would.
Old 04-12-13, 10:55 AM   #9
gt900uk
The fairings have that white tiger glue holding some sort of black foam stuff on the to edge. I am assuming this should be the double sided tape as per the instructions and the neoprene buffers (whatever they are) don't seem to be present.
Old 04-12-13, 12:53 PM   #10
the bike has been crashed and the lowers have been fixed or new ones put on but the brackets have not been replaced. the bracket on the right is not even fixed in place. i would suspect that the main frame brackets have also been damaged as well and this is why everything is sitting squint.
where in scotland are you?
Pointy with lower fairing fontmoss Stuff Wanted 4 20-10-13 09:05 AM
Lower fairing fitting kit (for pointy) ophic Stuff Wanted 20 19-07-10 04:02 PM
LH lower fairing for a pointy svrob Stuff Wanted 1 25-06-08 09:10 PM
Lower right fairing for a pointy MattGriff Stuff Wanted 0 22-06-07 10:30 AM
pointy lower fairing sv650s_guy For Sale - SV's and SV related items 6 30-04-06 07:01 PM
