Old 23-12-13, 08:40 PM   #1
Knobby
Question LED Strip lights
Was looking on ebay and saw these,
eBay item number:190857214668
I wonder, can I just run the wires straight to either the battery direct or through my forum electrical gizmo thingy ?
It says that its got just two wires a + and - so could it be that easy?
Old 23-12-13, 10:03 PM   #2
Shawthing
Shawthing's Avatar
Default Re: LED Strip lights
Yes . That easy. Though you will have to extend the wires and allow for full extension of the forks.
You will want them to turn off, so connect them to a switched +ve.
These should consume about 3.6W each so wiring them both into one of the Gizmo's outputs looks ideal.
SK9 Sport Black Delkevic can.
Old 24-12-13, 12:02 PM   #3
Spikey12
they are very easy to fit, when i did mine its simply a case of i ran the negative wire to the battery and the positive wire to a switch with another wire running from the switch to the positive terminal on the battery, took 30 mins.
Old 24-12-13, 12:09 PM   #4
Tomor
Tomor's Avatar
Default LED Strip lights
I have something very similar stuck to my radiator on the street.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 24-12-13, 02:14 PM   #5
That 3m tape isn't the best stuff, although it is pretty decent. Back it up with some cable ties.
Also that heatshrink around the connectors can be crap with copper exposed under it, cut it off, blather in hot melt glue/silicon and re heat shrink. If you want them to last (not for the price, just for the fact I really, really can't be bothered doing stuff twice)
£13 is a lot of money for them, there are lots cheaper available.
Old 24-12-13, 03:24 PM   #6
sniff
sniff's Avatar
Looks GAY
End of.
sniff is offline   Reply With Quote
Old 24-12-13, 04:17 PM   #7
Knobby
I am a total **** when it comes to electrics so bear with me when I ask what type of switch will I need ?
I can do basic wiring i.e crimping connectors , so if sombody can explain very simply how to wire these led strips to my forum electrical gizmo that would be very welcome!!
thanks
Old 24-12-13, 04:34 PM   #8
Why don't you just have them with the sidelights?
Old 24-12-13, 04:38 PM   #9
NTECUK
NTECUK's Avatar
Don't forget to fit a fuse.
Old 24-12-13, 06:35 PM   #10
Knobby
Side lights and fuse. Would need simple instructions on how to do that
strip video barwel1992 Idle Banter 14 01-05-10 02:26 PM
No side lights, brake lights, rear lights and dashboard lights Shona Bikes - Talk & Issues 25 13-11-09 11:07 PM
how to strip paint...... Wideboy Idle Banter 5 09-10-08 06:03 PM
Took the SV to the drag strip khskenny SV Talk, Tuning & Tweaking 89 12-05-05 08:56 PM
Visor and this strip thing?? The Mass Bikes - Talk & Issues 3 17-04-05 04:46 PM
