Old 19-01-14, 09:37 PM   #1
muzikill
muzikill's Avatar
Default Headstock adustment spanner?
Ive got the socket, do i need any special spanner to adjust? Plus i suppose i need to replace any dust seals?
Old 19-01-14, 09:45 PM   #2
Default Re: Headstock adustment spanner
What are you doing changing bearings or what?
Old 19-01-14, 11:06 PM   #3
DJ123
DJ123's Avatar
Default Re: Headstock adustment spanner?
Nope, just a hammer & punch.
After releasing the top yoke, raise it up a smidge to give you room to unlock the locking collar and get to the 2nd one. (this won't be an issue if you are removing the yoke altogether)
BMW F800ST
Old 19-01-14, 11:15 PM   #4
muzikill
muzikill's Avatar
Default Re: Re: Headstock adustment spanner
Checking bearings and regrease.
Old 21-01-14, 02:55 PM   #5
johnnyrod
johnnyrod's Avatar
As daddyjob says you can gently kncok the ring around with a hammer and suitable drift, this is also pretty easy if the top yoke is in place i.e. clearance isn't great compared to when you only have the bottom yoke on. Don't overtighten!
headstock bearing granty92 Bikes - Talk & Issues 6 19-10-13 08:42 PM
Headstock nut crisis95 Stuff Wanted 4 01-04-10 04:40 PM
Anyone with a headstock stand? arcdef Guildford Massive 6 17-08-09 11:32 PM
Headstock stand £40 tomjones2 For Sale - SV's and SV related items 3 29-11-07 05:09 PM
Headstock bearings brolong22 SV Talk, Tuning & Tweaking 28 26-07-05 04:48 PM
