Old 16-03-14, 09:39 AM   #1
LewSpeight
LewSpeight's Avatar
Default Fitting heated grips - keep spinning round the throttle!
I've got oxford heated grips and have had them on since October-ish, no matter what I try to use to 'stick' them on, a few weeks later the grip starts spinning round the throttle thing.
The inside of these grips are just straight smooth plastic, no rubber, no ridges or notches.
Ive tried:
Electrical tape (worked best for a month or so)
Epoxy resin
Silicone
No more nails
Some plumbers pipe tape stuff.
Any ideas? It's getting frustrating now
Old 16-03-14, 09:43 AM   #2
Default Re: Fitting heated grips - keep spinning round the throttle!
Hairspray, seriously its what I've always used for my grips
Old 16-03-14, 09:46 AM   #3
LewSpeight
LewSpeight's Avatar
Knew somebody would reply with that. I used it religiously on my mountain bike stuff and it worked fine, when I tried it with these it works for about 150 miles before 'letting go'.
I think it's because these are just hard shiny plastic on the inside on the grips, and being heated doesn't help because it softens whatever I use.
Thanks for the prompt reply
Sent from my C6603 using Tapatalk
Old 16-03-14, 09:51 AM   #4
Then maybe you need to roughen up the plastic so whatever you use has something to grip onto.
Epoxy is too stiff to use, I'm surprised silicon didn't work, although it might be better leaving for a few days to really cure properly
Old 16-03-14, 09:53 AM   #5
LewSpeight
LewSpeight's Avatar
Yeh I may have to give that a go. I'll rough it up and try get some quick drying silicone
Old 16-03-14, 11:12 AM   #6
PyroUK
PyroUK's Avatar
+1 for roughing up the inside.
I'm surprised the epoxy didn't work as that normally "melts" rubber.
Depending on how the other stuff works you could try this..
Get a few bicycle puncture repair patches, stick them to the throttle tube and let them properly set. then after roughing up the inside of the grip use the glue you get in the kits. That may work better as it's 2 rubber surfaces binding then as opposed to the plastic of the tube.
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 16-03-14, 11:48 AM   #7
Nutsinatin
Nutsinatin's Avatar
I've used Renthal grip glue, never had any problems with it.
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 16-03-14, 02:37 PM   #8
SharkyRider
How high are you heating the grips upto? I used duct tape to get a tight fit then hairspray, slotted them on, left em for a good 2/3 hours then I used em but never heated up more than half way as was plenty warm..
Old 16-03-14, 05:54 PM   #9
TheRuffellator
+1 for rental grips glues and roughing up the edges with some wet and dry.
Old 16-03-14, 09:41 PM   #10
trudd
Superglue works for me.
Heated Grips, throttle sticking. newts924 SV Talk, Tuning & Tweaking 9 22-02-10 09:32 PM
SV K5 throttle tube - fitting heated grips. TeddyBearKing SV Talk, Tuning & Tweaking 5 07-12-09 10:23 AM
Fitting heated grips -Ralph- SV Talk, Tuning & Tweaking 8 24-11-08 11:17 PM
Fitting Heated Grips Grinch SV Talk, Tuning & Tweaking 12 14-03-06 09:30 AM
Fitting heated grips rwoodcock01 SV Talk, Tuning & Tweaking 3 02-03-06 09:15 AM
