Old 20-03-14, 08:07 AM   #1
Kenzie
Kenzie's Avatar
Default Lens advice D3200
Good morning all. I currently have a D3200 with the kit 18-55mm and a Tamron 70-300mm lens. I am looking to add another lens as the kit lens is ok for close up type photos and the Tamron is a bit big to carry all the time. I have been looking at the Nikon 18-105mm and the 55-200mm. I think the 105 will fill the gap nicely as I'm used the range of zoom from my Fuji HS10. What are your thoughts?
Old 20-03-14, 01:03 PM   #2
atassiedevil
Default Re: Lens advice D3200
I'd go with the 105 too. I've the 18-55 and 55-200 currently, would be nice to have somthing in the middle also that does "most things"
Old 20-03-14, 03:19 PM   #3
keith_d
keith_d's Avatar
Given that you've already got two zooms which cover the same area as the 18-105mm, I'd consider adding something else. The choice would depend on what you like shooting but here are a few suggestions:
Landscapes/travel : 12-24mm f/4
Portraits : 85mm f/1.8
Macro : 85mm f/3.5
Sports/wildlife : 300mm f/4
Low light : 35mm f/1.8
One or two of these aren't so cheap, but you should be able to pick up a decent used example.
Just my thoughts,
Keith.
Old 20-03-14, 07:40 PM   #4
Kenzie
Kenzie's Avatar
Problem is that I have been used to the HS10 and I would like a do-all lens. I know I cannot get the range from a single lens but I would like to try and cover wide angle to just over what the kit lens can offer.
Old 21-03-14, 06:31 PM   #5
jambo
jambo's Avatar
You can get a large range from one lens. Nikon sigma and tamron all do 18-200ish lenses.
Whether or not that is the right solution for you depends on your requirements. They're certainly convenient, and the optics are much better than they would have been a few years ago. They possibly won't be as sharp as a set of dedicated lenses but if the prefect lens for a shot is heavy, expensive and never with you it's not a lot of good.
Personally I shoot 90% of my photography with a 17-50mm f2.8 tamron as I discovered I find that focal length works for me and a wide aperture was important to me.
Depends what you need
Jambo
Sent without a real keyboard
Old 21-03-14, 06:39 PM   #6
Kenzie
Kenzie's Avatar
Flexibility is what I need really. Looking at the 55-200 at the mo.
Old 21-03-14, 08:09 PM   #7
Bluepete
Bluepete's Avatar
I'd look at the 18-200mm Nikkor. I had one and it's a very very good piece of glass.
Pete
Old 21-03-14, 08:52 PM   #8
Kenzie
Kenzie's Avatar
Nice lens, cost on that is a bit prohibitive though. I have been looking through the used lenses as well.
Thoughts:
http://www.cameraworld.co.uk/used-ni...x-vr-9619.html
http://www.cameraworld.co.uk/used-si...on-af-fit.html
http://www.wexphotographic.com/buy-u...-lens/p1550028
My reason for keeping the price down is that I am still learning on the DSLR and don't want to get too deep into lenses.
Old 21-03-14, 09:38 PM   #9
Bluepete
Bluepete's Avatar
MPB have the 18-200 from £199.
Import model Canon lens advice. Bluepete Idle Banter 2 03-09-13 01:54 PM
400mm lens Springbokki Photos 3 30-05-13 08:18 PM
Kit lens(es) or save up a bit more? Sir Trev Photos 3 22-02-13 10:48 AM
Wales Thru' a lens Cymraeg_Atodeg South & West Surfers 1 26-09-12 07:23 PM
Got a new lens (well to me anyway). rictus01 Photos 6 23-04-08 09:28 AM
