Old 14-04-14, 07:19 AM   #1
scandalthegood
Default Clutch problem not going into 3rd (07 pointy)
Hi all,
Tryed to take my 07 pointy sv650 into work, and couldn't get it into third, then it stuck in second, it's only done 7000ish miles, any ideas would be greatfull.
Thank
Frankie
Old 14-04-14, 10:08 AM   #2
muzikill
muzikill's Avatar
Default Re: Clutch problem not going into 3rd (07 pointy)
http://forums.sv650.org/showthread.php?t=126381
Do this 1st then check the below thread about checking behind the sporocket cover & chain for stiff links, gunge etc...
No noises from that area of the engine before it happened?
Old 14-04-14, 11:48 AM   #3
scandalthegood
No noises, I just washed and cleaned her, cleaned and lubed the chain. I'll give the link a try.
Thanks a lot
Frankie
Old 14-04-14, 12:01 PM   #4
scandalthegood
There's no pics on that link!
Old 14-04-14, 12:42 PM   #5
jambo
jambo's Avatar
Unrelated to the clutch, do you find it moves between 1st, neutral and 2nd OK, but won't go up into 3rd?
If so, check the gear linkage is moving smoothly. Sometimes the gear lever gets road gunge and corrosion build up and so doesn't move smoothly on its pivot. This stops it moving back to the correct position after the gear change which prevents the next gear becoming available via the shift star.
The SV has either got a gear lever that pivots on the left foot peg mount, or on a separate pin below with a circlip holding it on, I forget which setup is used for a K7. If you unbolt the linkage that connects the lever to the gear selector shaft by the front sprocket (note that one of the threads is reversed) the lever should move up and down very freely, if there's any resistance and it sticks, it'll need a clean and grease.
Jambo
pointy clutch switch and clutch lever leebex Stuff Wanted 1 03-03-13 08:18 PM
Problem with clutch? Philip663 Bikes - Talk & Issues 3 25-02-10 07:53 AM
Clutch problem. iainsalter SV Talk, Tuning & Tweaking 4 25-11-09 03:00 PM
Clutch problem samusamus SV Talk, Tuning & Tweaking 2 20-01-08 08:59 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
