Old 19-04-14, 02:12 AM   #1
Entropy
Default HID Fitting?
Have been doing a lot of reading. When fitting HIDS to the bike do I need some sort of delay relay or headlight relay? Anyone else had to do this or did they just plug it all in and it worked straight off?
Old 19-04-14, 05:42 AM   #2
NTECUK
NTECUK's Avatar
Default Re: HID Fitting
The kit should have instructions included.
Read this if you are converting a standard head lamp, so you know why you have a beam pattern that's naughty http://www.danielsternlighting.com/t...nversions.html
Old 19-04-14, 10:46 AM   #3
Entropy
Default Re: HID Fitting?
Oh I know its a naughty beam pattern and but its mediated by light pattern blockers, I am just tired of bulbs blowing on me consistently and having to pay out for more. Least HIDS will last that little bit longer. What I mean is that I have been reading that the stock wiring in the bike cannot carry the current consistent and that there is a drop to around 10v at the h4 plug. Is this the case and what can I do to remedy this? I have read about the Eastern Beaver H4 Dual Headlight Relay kit but its in the States and I cant imagine how long it would take to get here. Any local solutions? Tried to message Bibio to see if he has a fix for it but as yet no reply. Don't know when he was last on the forums.
Old 19-04-14, 11:04 AM   #4
NTECUK
NTECUK's Avatar
The ballast is supplied via a fuse direct from the battery
a relay will be used to switch it on and off
Old 19-04-14, 11:06 AM   #5
Entropy
Not this one. It comes with a relay piece that plugs into the ballast and then plugs into the original wiring for the H4. Then the ballast has two wires going to the HID bulb.
Sent using a device that allows me to coalesce my thoughts with radio frequency waves and transmit them over long distances.
Old 19-04-14, 11:06 AM   #6
Entropy
Bought from HIDS Direct if it's any consequence.
Old 19-04-14, 11:08 AM   #7
NTECUK
NTECUK's Avatar
does this help you .OK its a car twin system but you get the idea
Old 19-04-14, 11:13 AM   #8
NTECUK
NTECUK's Avatar
H4 well didnt they give you this
control bit is the plug in the existing H4 bulb harness
Old 19-04-14, 11:37 AM   #9
Entropy
This is the kit I bought - I have bought multiple kits like it before and have had no issues - don't know why I have 1 side lighting up and the other not. http://www.hids-direct.co.uk/hs1-h6m...s-35w-50w-55w/
Old 19-04-14, 01:49 PM   #10
Entropy
Right - went down and took the fairing off and fitted everything all over again. When tested, they worked perfectly. I screwed the fairing all together and bolted everything in and on final test the low beam doesn't work at all and only the high beam works. I have no idea what the hell is going on. Please someone help me - has anyone been in this position?
Fitting an end can, how? Yet again. Chris199 SV Talk, Tuning & Tweaking 12 22-06-12 10:12 PM
Been fitting .... Teejayexc SV Talk, Tuning & Tweaking 9 15-03-11 09:53 AM
R&G Fitting cb5_keith SV Talk, Tuning & Tweaking 14 25-06-08 11:53 AM
DIY Can Fitting Jackhammer SV Talk, Tuning & Tweaking 14 15-02-08 01:12 PM
Fitting CCC cuffy SV Talk, Tuning & Tweaking 57 27-01-06 09:36 PM
