Old 02-09-14, 07:15 PM   #1
Foot
Default Braking Feel?
Couple of questions, are my back brakes knackered if they barely slow the bike at all? I never use them unless I'm doing less than 30, and even if using them at 15 or 20 they take a silly amount of time for me to even notice them in use. So in practise I use them only when coming to an actual stop.
So when riding outside of 30 speed limits I only use the front brakes. I know you should use something like 70% front, 30 back, but the back as I say really seems to make any difference. Do you use your back brake much?
Every once in a while I practise emergency stops for peace of mind, experience and moreover cause it's fun to slam the brakes on! When you feel the front juddering, am I right in thinking that's the front just about to lock? Surely it's not the back wheel lifting up?
Old 02-09-14, 07:28 PM   #2
Default Re: Braking Feel
Your back brake needs a service, new seals and a good clean. get the crud off the piston, its probably seized
I've just done mine after similar symptoms
Old 02-09-14, 07:34 PM   #3
JulesW
JulesW's Avatar
Rear might need pads, fluid or bleeding or all three.
Bikes I've owned and loved:
Bridgestone 90, Honda CB175, Suzuki GT250, Yamaha YZ125, RD350LC x2, RD350YPVS x2 & FZR600, Honda CB900F, Suzuki SV650S K6, 2014 Triumph Street Triple R
JulesW is offline   Reply With Quote
Old 02-09-14, 07:54 PM   #4
mep
mep's Avatar
Get some new seals, strip and clean then. I have just done the same with mine an it made a real dfference. The back caliper is more difficult to strip and clean compared to the front IMO as the pistons are opposed. If in doubt at least take them off and take them to a garage. You won't regret it.
mep is offline   Reply With Quote
Old 02-09-14, 08:29 PM   #5
NTECUK
NTECUK's Avatar
Front wheel lock. I usually notice the front suspension unload /pop up.
Best practice it out of the way.
Old 02-09-14, 10:39 PM   #6
Foot
Thought as much, I was sure the brakes wouldn't be good enough to bring the back up.
So is this optimum braking, just before the wheels about to lock? Or is that too close to the wheel locking and will end up taking longer to stop?
Of course, I don't think drivers look too kindly to emergency stops for no reason...
Old 03-09-14, 06:48 AM   #7
NTECUK
NTECUK's Avatar
You can do a stoppie on the SV with standard brakes if they are in good condition.
Stoppies are just a stunt not how to slow fast.
Your max brake power is squeeze the brake not jam it on. Just before the lock point is max deceleration.
Old 03-09-14, 07:41 AM   #8
Bike in avatar is a Pointy, so it's even easier than the front - only one piston.
True.
Old 03-09-14, 09:36 AM   #9
Jayneflakes
Jayneflakes's Avatar
It so easy to pop out the single piston using the master cylinder to pump it. Another reason to love the pointy.
I have just done mine and used an old bottle of brake fluid to pump the piston out. I have not done this job for a couple of years and the filth build up was shameful. I admit it, I was lazy and it nearly cost me the price of a new piston. However it cleaned up and polished well, combined with red rubber grease and nice shiny seals, the movement on the piston is so smooth it should be in a white suit on the disco dance floor!
Jayne you're a Pussy Magnet
Old 03-09-14, 09:52 AM   #10
NTECUK
NTECUK's Avatar
Default Re: Braking Feel?
Still the frame on the pointy looks like a rough night in Brighton
braking problems kiggles Bikes - Talk & Issues 28 07-04-11 02:59 PM
Suspension and Braking danf1234 SV Talk, Tuning & Tweaking 2 26-03-10 05:19 PM
Braking problems andyb SV Talk, Tuning & Tweaking 3 06-09-07 11:13 AM
Clunk When Braking. Alastair SV Talk, Tuning & Tweaking 6 23-08-07 05:02 PM
Braking an engine svrash For Sale - SV's and SV related items 1 22-03-06 10:43 AM
