Old 26-11-14, 04:38 PM   #1
Jake01
Default Sv wiring harness
Hey guys, I recently had issues with my meta alarm, put bike into garage and he
Said wiring was a right state and alarm hadn't been installed properly.
He said it would be easier to replace the harness altogether
Went and got a harness took it in and he said it would only be a couple of hours labour to change it.
Called me today and said Bill was £647.74 would that be about right
Old 26-11-14, 05:29 PM   #2
figaro
Default Re: Sv wiring harness
No, it's an hour's work. I fitted a complete new harness to my SV1000 for the same reason, took me less than an hour and I'm not a mechanic. And I had problems cos the replacement harness was US spec. Reckon you're getting shafted there.
Old 26-11-14, 05:34 PM   #3
Jake01
Yeah thats what i thought,here is the garage note that came with the invoice,trying to say they spent 10hrs on it -
Attempted to repair existing harness but the harness is beyond economical repair.
Stripped body work, removed airbox.
Drilled out seized bodywork and screen screws.
Air filter is very dirty on removal of airbox - Cleaned and re-oiled..
Stripped out old harness and fitted new harness (supplied by customer).
Extended tail light connector and re-terminalled.
Rebuilt all bodywork and airbox.
Old 26-11-14, 05:50 PM   #4
sounds about right for Shirlaws.
Old 26-11-14, 05:58 PM   #5
figaro
They didn't even supply the harness..?
Old 26-11-14, 06:02 PM   #6
Jake01
no i supplied it myself,was a garage in Aberdeen - Moto Meccanica
Old 26-11-14, 06:20 PM   #7
figaro
So how much do they charge an hour?
Old 26-11-14, 06:32 PM   #8
Jake01
£50 p/h + Labour
Old 26-11-14, 06:43 PM   #9
figaro
So it took some professional mechanics a day and a half to do what I as a rank amateur did in an hour. You're getting robbed mate.
Old 26-11-14, 08:24 PM   #10
Jake01
Yeah i thought so too, I would have said at a max maybe 5 hrs at a push,
I could have passed out when i got that bill - think i may need to go see them tomorrow
Pointy S headlight wiring harness. GoodKat Stuff Wanted 0 25-10-12 02:29 PM
Rebuilding curvy wiring harness? Lucas SV Talk, Tuning & Tweaking 4 17-11-11 03:37 PM
veypor wiring harness sv_rory SV Talk, Tuning & Tweaking 3 30-05-08 06:16 PM
Wiring Harness,cable and hose routing 21QUEST SV Talk, Tuning & Tweaking 3 19-05-07 04:48 PM
Front Headlight wiring sub harness (curvy S) Tim in Belgium Stuff Wanted 5 13-12-06 12:25 PM
