Old 09-01-15, 09:20 AM   #1
Tommo1988
Default Swinging arm bearings- where from?
Been told I need to replace mine. Where's best to purchase. Cheers.
Old 09-01-15, 09:24 AM   #2
Corny Gizmo
Default Re: Swinging arm bearing advice please.
Bibio posted this the other day, they are for a pointy I believe and are currently half price
Click Me!
Old 09-01-15, 09:24 AM   #3
Tommo1988
Thanks very much
Old 09-01-15, 09:26 AM   #4
Tommo1988
Sorry are all the bit on that page compatible with the sv?
Old 09-01-15, 09:28 AM   #5
Corny Gizmo
It should only be showing one part number: 09263-25059 but they do a lot of other parts,
This is Bibio's Quote:
also the Pointy 650 swingarm bearings are on less than half price (£14.90 each) offer at the moment. part code 09263-25059 so get them while you can.
Old 09-01-15, 09:31 AM   #6
Tommo1988
Spot on yea it does I just couldn't see stuff for sv just bandits
Old 09-01-15, 09:37 AM   #7
TamSV
TamSV's Avatar
What were the symptoms that led to the advice that replacement bearings are required?
In many pointy SV's there seems to be a bit of side to side play in the swingarm that won't necessarily be fixed by new bearings.
Have a read here - clicky
Old 09-01-15, 10:26 AM   #8
Tommo1988
Just read the huge thread the play is side to side on mine too. I just called ma Mech telling him about the shims he's still saying I should replace my bearing too as I'll have the arm off anyways.
Old 09-01-15, 02:34 PM   #9
TicklinJock
TicklinJock's Avatar
Default Re: Swinging arm bearings- where from?
May be worth finding out which bearings are causing the play.
My MOT fail slip said "excessive swingarm" play... and found it was caused by the shock linkage knuckle bearings. This caused play in the vertical direction. Worst one on mine was the one that connects the knuckle to the frame. Bought a couple of sets from different suppliers as I found they had play in them from new. Fitted the ones that had the least play and a year later they got a mention in the next MOT... not for "excessive" that time though.
TicklinJock is offline   Reply With Quote
Old 09-01-15, 03:39 PM   #10
there should be no up down movement on the swingarm but suzuki say that side to side is normal. i have a little up-down play due to not replacing the washers on the knuckle to frame which causes he inner bearing to move on the bolt.
if the MOT inspector has only felt side to side play then ask him/her to phone suzuki but i doubt you will get anywhere with this.
GSXR600 swinging arm in a curvey? NTECUK SV Talk, Tuning & Tweaking 26 22-10-11 09:26 PM
Swinging arm bearing gap Mannerheim SV Talk, Tuning & Tweaking 13 09-12-09 08:54 AM
K4 swinging arm on 2000 SV Naked Curvy Sloth SV Talk, Tuning & Tweaking 3 29-11-05 02:21 AM
Swinging arm pivot greasing curium SV Talk, Tuning & Tweaking 3 03-04-05 04:40 PM
