Old 04-04-15, 11:23 AM   #1
scoots
Default Any ideas???
whilst riding ive noticed a clicking noise coming from the bike, ive tensioned the chain correctly and aligned the wheel correctly, ive removed the fairing and the front sprocket cover and put the bike on a paddock stand, when in gear the chain seems to jump now and again...why does this do this??? the chain and sprockets look to be in good condition. im worried it may come off when riding...any help appreciated thanks in advance..
Old 04-04-15, 12:02 PM   #2
Sir Trev
Sir Trev's Avatar
Default Re: Any ideas???
Don't forget your chain will be tensioned differently with the suspension loaded and you on it. Running the bike on a paddock stand will not give you a good idea.
Old 04-04-15, 12:28 PM   #3
Fen Tiger
Last time I had a similar noise I found the front sprocket was hooked.
Fen Tiger is offline   Reply With Quote
Old 04-04-15, 12:31 PM   #4
you may have a tight link in the chain.
Old 04-04-15, 03:43 PM   #5
scoots
cheers for the input guys...u may have a point with the tight link..i will give it a good lube but I do have a scotoiler....any ideas on best chain lube?
Old 04-04-15, 08:33 PM   #6
Heorot
Scotoiler own label oil in your scotoiler.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 04-04-15, 09:03 PM   #7
get some paraffin and a 2'' paint brush. cut the bristles of the 2'' brush in half so you have stiff bristles. get a clean glass jar (mayonnaise are ideal) and pour some paraffin into the jar. put a kitty litter tray under the chain area then clean chain with the paraffin and brush. when cleaning the chain pay special attention to any tight links by wiggling the link while its doused in paraffin. once the chain is clean pour the paraffin that is in the litter tray back into the jar then put the lid on the jar. with luck you will clean the chain enough to free the tight link, if not then get a new chain or put up with the noise.
the paraffin will settle out in the jar for future reuse. a 4ltr pack of paraffin will last you years and years doing it that way.
Old 05-04-15, 07:52 AM   #8
scoots
ok i will give it a try thanks
Old 06-04-15, 07:29 PM   #9
Red Herring
Red Herring's Avatar
Just thinking laterally, you haven't got a big screw or similar in the back tyre have you...?
Old 06-04-15, 07:57 PM   #10
scoots
no ive checked the tyres as well,,,think I will just treat myself to new chain n sprockets
ideas please busasean Idle Banter 6 29-02-08 05:41 PM
Any Ideas? melody 2007 Annual Rideout 22 17-06-07 12:55 PM
Out of ideas on this......help please. POGS69 SV Talk, Tuning & Tweaking 29 24-05-07 07:51 AM
Oil.. Any ideas????? k3lls SV Talk, Tuning & Tweaking 11 04-05-06 01:08 PM
