Old 17-08-15, 01:00 PM   #1
craigmcgleish
Default Brake pedal click
Hi all
Having a clicking problem with my rear brake pedal almost as if the spring is slipping pedal goes hard brakes on then click and pedal is then pushed down further to the ground anyone any ideas?
Also looking to get new rear disc and pads can you recomend any?
Old 17-08-15, 04:04 PM   #2
Default Re: Brake pedal click
Perhaps there's a build up of crud in the pivots, give it a good clean out.
OEM disc, pads I've used Kyoto ones before & they've been fine. Or see if the Chinese manufacturer that Garynortheast used for his front discs replacement, makes one for the rear. I bet they do, as its a disc that's used by a lot of other Suzuki's
Old 17-08-15, 04:08 PM   #3
craigmcgleish
ok no problem thanks
Old 17-08-15, 05:06 PM   #4
Alexander94
I had a similar sounding problem when I replaced my brake pedal, the rod that gets pushed my the pedal into the master cylinder wasn't getting pushed straight.
I've got a £25 Arashi rear disc on the way from China, they're meant to be pretty good.
A friend of mine swears by Goldfren pads but some people don't like them. I think I'm going to try SBS sintered pads, they're about £19 for the rear and £35 for the front.
Changed brake pedal, brake light stays on. Rabnawaz SV Talk, Tuning & Tweaking 6 10-02-12 07:16 PM
RH Brake Pedal wahwah Stuff Wanted 0 08-05-10 11:11 AM
Curvy brake lever & rear brake pedal Old Git Stuff Wanted 1 09-01-10 11:00 AM
Click Click Click Under Braking TSM SV Talk, Tuning & Tweaking 6 26-08-06 06:23 PM
click, click from front brakes triumph5ta SV Talk, Tuning & Tweaking 14 18-07-06 10:19 AM
