Old 05-09-15, 06:18 PM   #1
ClunkintheUK
Default OMO: Macbook dual boot issues
So, my macbook pro recently ran out of battery rather fast, i.e. before I could power down. I had a dual boot of MacOS 10.6.8 and Linux 12.4.
After the battery crash it no longer gives me the option for which operating system (the refit screen), and I have no way of starting up Linux, which is really the operating system I use most on it anyway. It also forgot all my history in browser, my wifi password and even down to what time it is, though that has sorted itself out once it has connected properly. The first few reboots, it kept forgetting all this between reboots, and when going to the google homepage on Firefox it kept deciding that I did not have a trusted connection. It was fine before.
Anyone else had this, or even fancies offering an opinion on what is going on, cos I have no idea.
Old 05-09-15, 06:41 PM   #2
Default Re: OMO: Macbook dual boot issues
As you start up press and hold cmd and d from memory it'll allow you to select disc
sent with all the fury of a clogged drain!!
Old 05-09-15, 06:49 PM   #3
ClunkintheUK
Any idea what caused the issue of it forgetting the refit stuff?
Old 05-09-15, 07:05 PM   #4
I'm having the reverse issue as mine won't hold charge
The NRAM will have reset which holds that information
Restricted ECU Pointy. 07 onwards (dual spark) Dual pin/connector safekyle For Sale - SV's and SV related items 6 17-04-14 09:22 AM
MacBook Pro - Dual booting sauluk Idle Banter 23 13-02-10 11:37 PM
IT Help Req'd - Dual Boot Supervox Idle Banter 20 31-01-10 01:56 PM
FS: Macbook Neeja Idle Banter 21 13-12-09 12:49 PM
dual spark plugs (and issues) ELR4ever SV Talk, Tuning & Tweaking 14 24-01-08 10:01 AM
