I have a 2006 SV and I'm pulling my hair out trying to get the coolant reservoir out.
I looked at the parts diagram and it said there is the left upper bolt by the plastic arm-shaped hanger you can visibly see through the frame. The diagram also says there's a second bolt on the backside of the reservoir holding it to the metal bracket. But I can't find it by sticking my hand down there looking for it. I doubt I could reach it either, even if I could find it. Does anyone know how to remove the coolant reservoir without taking the engine out? |
Your answer appears to be here:
As i have the engine out it was worth a check, this little bottle has overflow rubber hoses coming in and going out and is a very important part of your engines ability to keep cool and breath! As per Muzzikill's post. A lot of effort for little gain unless you HAVE to get the bloody thing out!! In which case I feel your pain.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am. 05 SV650s now with proper suspension, hurrah! |
I took mine out on a 2004 model without removing the engine, its doable but really tight.
I can't fully remember how, may have taken it out downwards after moving the big coolant pipe from radiator to coolant pump. |
#4 | |
Coolant reservoir - worth a check! | muzikill | SV Talk, Tuning & Tweaking | 7 | 22-10-15 01:08 PM |
Coolant removal - how? | granty92 | Bikes - Talk & Issues | 9 | 11-05-13 05:18 PM |
White "sludge" on inside of oil and coolant reservoir. | smuirhead94 | Bikes - Talk & Issues | 11 | 19-04-13 08:44 PM |
rear master cylinder reservoir removal. | Whitty | Mini-Twins | 7 | 09-04-12 10:28 AM |
Curvey coolant reservoir | Neeja | Stuff Wanted | 3 | 26-10-09 11:02 PM |
