Hardware Post your own reviews, opinions and experiences on this subject.
Old 03-12-15, 05:54 PM   #1
Fenrisulf
Default Rear brake light switch
Hi all, I'm a newbie so forgive me if this thread has been repeated. Has any one got any experience of the Woodcraft rear brake light switch. http://www.motosport.com/woodcraft-rear-brake-light-switch . I believe its an upgrade replacement for the standard spring pull down switch on the SV650S 2003. As I'm having some trouble with the spring tension and adjustment on my original switch set up.
Thank you
Old 04-12-15, 05:37 PM   #2
Default Re: Rear brake light switch
Not that make in particular, but I've had banjo bolt switches before and never had any problems with them. It's a much neater solution. Just make sure you get the correct thread pitch
Old 05-12-15, 11:30 AM   #3
Fenrisulf
Thank you for the information, I think I will give it a try they are not really expensive and as you say it is a much neater arrangement. just the hassle of bleeding the system I suppose.
rear brake light switch ClunkintheUK SV Talk, Tuning & Tweaking 7 19-03-15 04:39 PM
K6 rear brake light pressure switch. leebex SV Talk, Tuning & Tweaking 11 23-11-12 09:55 AM
Curvy rear brake light switch? daveyrach SV Talk, Tuning & Tweaking 7 17-10-12 12:28 PM
Rear brake light switch yorkie_chris Stuff Wanted 1 04-06-11 08:45 PM
Rear brake light switch dirtydog Stuff Wanted 4 29-12-06 08:50 PM
