Hello I have a early sv that will not run on the rear cylinder .i have done a compression check and its the same as the front.i removed the head and all valves seem to be ok.i have also changed the carbs but it still oils up the plug and wont start unless I warm the plug.help
Is it starting on both cylinders when you warm the plug or just the one? i.e.: does it run on the rear cylinder at all?
Is there a spark at the rear plug?Are you sure it is oiling up or could it be fouling with unburnt fuel?If its oil it must be coming down the valve guides or via worn piston rings/bores.Fuel fouling could be flooding carb or no spark.I assume you already checked all this before taking the lid off.
Have you checked the coils?
+1 If plug is OK, I would also suspect coil or a leak between coil and plugs.
Rear cylinder not firing after front cylinder rebuild | Littlewebber | Bikes - Talk & Issues | 2 | 17-07-13 08:45 PM |
Bike refuses to warm up, Triumph Tiger. | Galviniser | Bikes - Talk & Issues | 19 | 10-04-13 09:41 AM |
TDC on the rear cylinder? | 5hort5 | SV Talk, Tuning & Tweaking | 9 | 01-01-10 03:25 AM |
Crash.NET - West refuses to give up on MotoGP dream. | NewsBot | News | 0 | 22-10-08 06:40 PM |
RTA where party refuses to give details | Red ones | Idle Banter | 31 | 21-08-06 12:10 PM |
