Old 06-12-15, 05:29 PM   #1
Janda
Default Flasher Relay
Hi
Fitting new led indicators and purchased this relay. Any idea which 2 wires to connect it to ? Cheers
GO GO GO
Old 06-12-15, 06:06 PM   #2
AlexAdams
Default Re: Flasher Relay
Cant help but you can buy led specific 7 pin relats which are about 15 quid.
Old 06-12-15, 07:34 PM   #3
DJ123
DJ123's Avatar
What bike/year is it?
As above, get a 7 pin relay for a Suzuki and it'll sort out the fast flashing you get with LED indicators.
BMW F800ST
Old 06-12-15, 07:35 PM   #4
Janda
It is k8 naked ,found actually info at svrider
http://www.svrider.com/forum/showthread.php?t=163261
GO GO GO
Old 11-12-15, 12:37 PM   #5
Janda
Job done
GO GO GO
Old 11-12-15, 06:30 PM   #6
Toooldtodie
Toooldtodie's Avatar
Resistors are a cheap and easier fix. They should come supplied with the indies, but can be bought from Maplins, etc. Just make sure they're clear of other wiring, plastics, etc. as they get warm/hot enough to melt plastic and get the right resistance (bulbs have quite a high resistance).
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 19-12-15, 09:18 PM   #7
s7even
i fitted led`s, i used this and it worked a treat
http://www.ebay.co.uk/itm/SUZUKI-GSF...item5d3c8b2593
Old 19-12-15, 09:24 PM   #8
Janda
I bouth that for £4 and work as well,dunno about how hot it gets,how long it will last and so on,will fnd out after winter
GO GO GO
pointy flasher relay JohnStMartin Stuff Wanted 2 10-11-13 09:50 PM
How do you test a flasher relay? warrenhewitt10 Bikes - Talk & Issues 13 21-02-10 02:09 PM
Where is my flasher relay(s)? Lost@Home SV Talk, Tuning & Tweaking 5 30-01-10 02:51 PM
problem with flasher relay. fourstrokebeast SV Talk, Tuning & Tweaking 10 30-03-08 07:22 PM
Flasher Relay installation - might have done something bad... R-Razor SV Talk, Tuning & Tweaking 7 07-10-07 12:28 AM
