Old 09-02-16, 04:29 PM   #1
shiftin_gear98
shiftin_gear98's Avatar
Default Burgular Alarms?
OMO, thinking about getting the above. Anyone got any info to share.
Just checked my area online and in Dec there were 2 break ins, compared to 44 in Chingford. Link on ADT website. Another good reason to have moved.
So hopefully not a high crime rate. Just after piece of mind really.
Thinking of a Yale DIY system as don't have limitless funds.
Something like this - http://www.screwfix.com/p/yale-premi...larm-kit/54473
Any advise, comments welcomed.
Currently driving a Corsa....
Old 09-02-16, 06:55 PM   #2
Sir Trev
Sir Trev's Avatar
Default Re: Burgular Alarms?
The real crims will know the difference so if you want peace of mind get a few quotes on a pro fit one. They will be guaranteed and should be well fitted. ADT are shockingly expensive and are geared towards commercial and high end so look for a local outfit who will want your recommendation. If it's too expensive then see if a friendly sparky is up for helping you put in a simple system.
Old 09-02-16, 08:02 PM   #3
damienga15de
I don't know if you get them in the uk , but hkc are the best we have here never give any trouble and a hybrid panel does wired and wireless
Old 09-02-16, 08:27 PM   #4
Mickle
I have just installed that Yale system in the mother in laws house, easy to fit and works fine, the siren is f,f,f,f loud!
Old 09-02-16, 09:37 PM   #5
Bri w
Bri w's Avatar
Avoid ADT!!
If you're technically good enough, pick a good one and diy.
Old 09-02-16, 09:53 PM   #6
Avoid adt
Their gear is modified honeywell galaxy g2 and rio.
Any good wholesalers or local alarm company can supply
Sent from my E2303 using Tapatalk
Old 09-02-16, 10:06 PM   #7
mattSV
mattSV's Avatar
Another vote for Yale. Fitted one after my Jag was stolen from home a couple of years ago. Easy to fit ( no wires to run). The version I have phones me on mobile if alarm triggers. Also has the option to set with configurable home or away options (eg exterior. Door sensors only or all doors plus PIR sensors). Farkin loud bellbox and deafening interior sounder.
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 10-02-16, 08:15 AM   #8
Avoid adt
Should have added
The honeywell alarm kit is excellent. Used in all commercial installs I've dealt with
Old 11-02-16, 07:31 AM   #9
shiftin_gear98
Thank you all for your input, appreciated.
Old 13-02-16, 11:33 AM   #10
ethariel
ethariel's Avatar
ADT - Another Disastrous Testimonial.....
Ok on fire alarm systems in a commercial sense but not home alarms.
ethariel is offline   Reply With Quote
ADT alarms Amadeus Idle Banter 31 08-09-12 05:13 PM
Alarms newts924 Pennine Massive 3 22-04-08 02:55 PM
Alarms silver surfer SV Talk, Tuning & Tweaking 18 12-06-07 06:08 PM
Alarms? seandixie Bikes - Talk & Issues 8 24-01-06 05:25 PM
Alarms - Worth it or Not? jordyal Bikes - Talk & Issues 24 12-08-04 06:42 PM
