Old 11-04-16, 08:54 PM   #1
L3nny
L3nny's Avatar
Default R6 Throttle Mod on Pointy
Throttle is sticky on my 2005 pointy so decided to try the R6 mod, anyone know what exactly I need to do and what year R6 I need it from.
Ta
2015 GS 1200 Adventure
Old 11-04-16, 09:34 PM   #2
Redmist
Default Re: R6 Throttle Mod on Pointy
I'll be doing the exact same thing on my latest purchase (Already did it on my track bike) so I'll be buying one of these: http://www.wemoto.com/bikes/yamaha/y...es_pipe_-_oem/
You just need to compare it with your existing tube and cut some of the guide down.
If you hold the tube vertical in front of you with the "holes" for the cables closest to you, its the left hole which has some trimming required on its entry. Do it very careful and in small lumps as its very brittle!
I also recommend using some cut down tie wraps superglued into the throttle housing to act as a cable guide. I did have a photo but imageshack may have deleted it
Old 11-04-16, 09:36 PM   #3
Redmist
If it comes back, the image is here:
Old 12-04-16, 08:18 AM   #4
L3nny
L3nny's Avatar
Image isn't working, I found a few Youtube videos though so have a pretty good idea on what needs doing. Cheers.
Old 13-04-16, 09:20 PM   #5
Redmist
Just added the "cable guides" to my throttle road bike housing, as I say just cut down cable ties superglued in place. Been like that on my trackbike for over two years with no issues.
I found it to be the only reliable way to stop the cable slipping off the cam.
Old 14-04-16, 10:00 AM   #6
DomP
Excuse my ignorance but what are the advantages of doing this?
DomP is offline   Reply With Quote
Old 14-04-16, 10:11 AM   #7
Corny Gizmo
Shorter twist to get to full throttle essentially, The SV has quite a lot of throttle travel to get to full whack, the R6 tube has a larger cable guide (I think) and that makes it quick action so to speak.
Im sure someone will correct me if im wrong but thats the general gist.
Old 14-04-16, 10:34 AM   #8
DomP
Ooo, sounds like a cool mod. I like these small easy mods, there should be a mods/tweaks section on this part of the forum
Old 14-04-16, 12:06 PM   #9
L3nny
L3nny's Avatar
Thanks for the link and the info. I've placed an order, see how it goes
Old 14-04-16, 02:54 PM   #10
Best £10 I've spent on my sv
Pointy S throttle housing. SikFiddy Stuff Wanted 0 08-12-15 01:27 PM
R6 throttle tube mod - Pointy? Fifteen15 SV Talk, Tuning & Tweaking 16 15-06-12 07:30 PM
Pointy throttle troubles Kyleton7 Bikes - Talk & Issues 8 19-04-12 06:46 PM
pointy 650 throttle body f/s jimathyy For Sale - SV's and SV related items 0 29-02-12 04:47 PM
pointy throttle tube andyrs Stuff Wanted 3 20-08-09 03:17 PM
