Old 21-05-16, 06:57 PM   #1
EliteAlex
Default New member, new biker: wanting an sv650s as first bike
Hi all,
I'm just getting to biking and have just got all of my gear sorted. I am looking for a used pointy sv650s. I'm browsing the adverts and looking about for one but i'm unsure about the mileage of the bikes. I assume the lower the better but some of them i've seen which have between 20,000 and 24,000 but for a very good price. Is this considered too high or enough to look for a lower mileage one? The bike will be used at the weekend as a toy.
I'm on an A2 license so the bike will need to be restricted and as such i won't be able to test ride before buying, which is a bit annoying, even at a dealer! I've never ridden a 'sportsbike' position such as the SV, only a naked so i won't know if i'll like the riding position until i've bought it!
Any help or opinions would be greatly appreciated!
Old 21-05-16, 08:08 PM   #2
Default Re: New member, new biker: wanting an sv650s as first bike
Welcome!
20-24k wouldn't bother me in the slightest.
Re riding position you'll be fine with either, the SVS isn't ridiculously sporty.
Old 21-05-16, 08:14 PM   #3
EliteAlex
Welcome!
Thanks for the reply mate. What sort of mileage would recommend staying under for purchasing sake? I've seen fome with like 47,000 on so the engine must be fairly bulletproof?!?!
Good, i'm sure i'd get used to it soon anyway!
Old 21-05-16, 08:32 PM   #4
Mine lasted to 100k no problem and was still fine, bit rattly but it did get a very hard time.
It's all maintenance and condition dependent really
Old 23-05-16, 07:39 PM   #5
AlexAdams
15k valve clearance service come in around £250-£350 so factor this if approaching 15k intervals.
Old 23-05-16, 07:49 PM   #6
EliteAlex
Thanks for the info. I'll definitely factor this into the search criteria! I've actually messaged one bloke and he told me he hasn't had the valve clearances done and the bike is at 16,000. He said that a mechanic friend told him they are never out of clearance, even at 20,000+. I guess its a case of buyers beware!
Old 24-05-16, 10:45 PM   #7
Heorot
It should only cost that much if they are found to need adjusting. I had mine checked as part of a service at around 15k and wasn't charged for more than an hour because adjustment wasn't necessary. From earlier threads here,it seems that's generally the case.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 25-05-16, 06:41 AM   #8
They don't normally need adjusting, but when they need it they need it.
Old 25-05-16, 06:50 AM   #9
EliteAlex
Thank you all for the info. From what i've heard they're pretty bulletproof engines so as long as i find one thats been looked after well, and serviced regularly etc, i don't need to worry too much about mileage. I'll have a search of the forums to find out common faults and things to look out for when buying to save any more repeated threads!
Old 25-05-16, 10:03 AM   #10
Balky001
Balky001's Avatar
Good luck finding the right bike. As others have said, 20k on an SV isn't a worry as long as its been looked after.
Chris, are there any telltale signs the valves might need adjusting without checking. Thought it might be useful as you never know if they have really been checked even if you pay for it.
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660
Balky001 is offline   Reply With Quote
New Rider wanting SV650s (K3+) (budget £1500-£1800) ManMango Stuff Wanted 6 01-07-14 11:23 PM
new to forum, just wanting to know a few things about sv650s 01 Joe Marcon SV Talk, Tuning & Tweaking 25 13-12-11 03:02 PM
New Biker, New Rider, New Member - Glenrothes, Fife PuggledPrune SV Ecosse 14 12-08-10 08:02 PM
New Member/New Biker North Glasgow RiotCop66 SV Ecosse 17 12-08-10 10:02 AM
Newbie wanting to buy SV650s rpwoodman SV Talk, Tuning & Tweaking 12 11-01-05 02:13 PM
