Old 30-09-16, 08:20 PM   #1
Mickle
Default Petrol smell when cornering
Afternoon guys,
Anyone heard of this before?
Went out for a ride with mates, the guy following me reported a strong smell of petrol when I corner enthusiastically on my K2. Can't find anything wrong with the fuel lines and no staining you would expect from a leak, the filler cap seal looks ok too! This has been mentioned on a few occasions, and not only when I have recently filled up,
Bit baffled at the mo,
Thanks in advance
Mike
Old 01-10-16, 03:12 PM   #2
Sir Trev
Sir Trev's Avatar
Default Re: Petrol smell when cornering
What's your mpg like? I know it varies from week to week and person to person but it may be a clue.
Old 01-10-16, 03:26 PM   #3
TicklinJock
TicklinJock's Avatar
I get the same remarks about my K5.
I assume its overfuelling when accelerating, so those behind smell the unburnt fuel from the exhaust.
TicklinJock is offline   Reply With Quote
Old 01-10-16, 09:22 PM   #4
Mickle
Consistent 55.3 +\- 5 depending on wether In chasing the other half around on her 125 or ****ing off the power rangers on their rocket ships
Old 02-10-16, 08:22 AM   #5
fizzwheel
fizzwheel's Avatar
What bike ?
Old 02-10-16, 08:01 PM   #6
Mickle
2002 sv650s carb model
Old 02-10-16, 08:09 PM   #7
Maybe the tank drain pipe has a hole in it, so it's leaking out of that.
Other than that a bit of unburnt fuel on the overrun
Old 04-10-16, 12:01 PM   #8
As Mavizap has suggested, the drain tube from the filler well can leak. If you open the cap, at the front right of the well you will see a hole, this is a tube that runs right through and out of the bottom of the tank, it can suffer from rust that causes it to rust through, or to become detached from the well of the tank. It's happened to a number of early SVs, and seemingly difficult to trace fuel smells are a common indicator of this.
Old 05-10-16, 06:01 AM   #9
Mickle
Oh joy!! Thank you boys, I will investigate that.
I notice the fuel cap is sitting very slightly up when locked ( about 2mm ) I am wondering if fuel could be getting past the cap seal and leaving via said pipe?
I get no puddles of fuel ( or staining from ) when the tank is full and the bike in the garage
Old 05-10-16, 06:01 AM   #10
Mickle
Petrol smell from exhaust. 18sv650 SV Talk, Tuning & Tweaking 7 28-02-12 01:12 PM
Oddly occuring petrol smell Owenski Bikes - Talk & Issues 0 01-09-10 11:24 AM
smell of petrol AndyBrad SV Talk, Tuning & Tweaking 5 06-10-08 03:26 PM
Anyone smell petrol? Defender SV Talk, Tuning & Tweaking 13 20-09-07 05:16 PM
Reported petrol smell -K4 injury_ian Bikes - Talk & Issues 3 05-09-07 10:26 AM
