Old 04-02-17, 09:02 PM   #1
DomP
Default Pointy rear shock upgrade
I'm hoping to upgrade my rear shock this spring or summer but looking on ebay the zx10r 'no cuts necessary' ones seem to go for loads and probably have loads of miles on them too. Should I be expecting to pay £150+ for one? 10 to 10 1/2 stone with no gear on if that helps
DomP is offline   Reply With Quote
Old 04-02-17, 09:14 PM   #2
Kev8611
Default Re: Pointy rear shock upgrade
I used a K4 gsxr 1000 shock. Got it for £80. Had to cut the battery tray and remake it with some metalwork but totally transformed my bike
Old 04-02-17, 09:22 PM   #3
DomP
I'm quite happy to lose the toolbox, I'm thinking of chopping it off anyway.
Old 04-02-17, 09:24 PM   #4
Kev8611
Yes i chopped that completely off along with the battery tray. Had to move some relays and extend the negative lead to the battery also.
Old 04-02-17, 09:35 PM   #5
DomP
Think I'd rather try and not have to mess with the battery tray if I could help it. I have removed the pointless battery tray guard or what ever it is called.
Old 04-02-17, 09:48 PM   #6
DomP
Do i ideally need to match the kg/mm with my fork springs?
Old 04-02-17, 10:23 PM   #7
as with any second hand rear shock you are going to need it serviced £100 then add the proper weight spring £60 this then takes you up to £300-400 for a second hand shock.
YYS, Nitron, Ohlins etc.etc built for your weight and serviceable for not that much more dosh. BTW any shock need serviced at or before 20k miles after that they are pretty much goosed. Nitron shocks keep a good resale value so you can expect at least 1/2 of what you paid for it if it comes time to sell.
if you do get a nitron dont be a fool and say its for racing get a road spec one.
and yes you need to upgrade the front springs while you are at it. also do a few we mods inside to forks.
Old 04-02-17, 11:43 PM   #8
DomP
I've done emulators and ktech springs with the weld and reaming out of the damper rod, made a very pleasing difference.
Think the rear may be waiting a while in that case.
Old 05-02-17, 12:06 AM   #9
yup, your better saving and getting a proper designed drop in shock rather than a hack. it sounds like a lot of pennies and it is to an extent which depends on how long you plan on keeping the bike. TBH depending on how many miles is on the standard shock they are not that bad, big difference with a decent shock is when you start to get a wiggle on round bumpy curvy stuff. the standard shock tends to let the bike wiggle its head as the dampening cant keep up.
contrary to popular belief stiff suspension is not good for road use. suspensions main criteria is to keep the rubber in contact with the tar while keeping the chassis stable.
Old 05-02-17, 09:43 AM   #10
This ones for a curvy, but they do pointy ones, price is good. If not look out for a 2nd hand Hagon shock, I've been happy with mine for ages, less than £200 if I remember
http://www.ebay.co.uk/itm/1718920699...%3AMEBIDX%3AIT
Rear shock upgrade Jardine SV Talk, Tuning & Tweaking 11 08-01-17 06:52 PM
Pointy rear shock upgrade info help. Tommo1988 SV Talk, Tuning & Tweaking 8 17-06-14 01:22 PM
What rear shock to upgrade to? cbay SV Talk, Tuning & Tweaking 27 18-06-11 04:04 PM
Rear shock upgrade marcosa Stuff Wanted 0 23-09-10 11:47 PM
Rear Shock Upgrade, furrybean SV Talk, Tuning & Tweaking 18 07-02-07 06:40 AM
