Old 29-03-17, 09:49 AM   #1
Craigg
Default Fork rebuild - squeaking
Hey Everyone
Finally got around to rebuilding my forks, with the modified damper rods and emulators installed. one of them seems to be perfect. however the other one when being compressed is making a "squeaking" noise.
i am thinking it must be something rubbing on the stanchion as its being compressed, but i am wondering if anyone knows of a likely culprit? i have re-seated the spring already, and i don't think it can be the washer/spacer at the top of the stack, as these don't really move.
the other fork is totally fine, completely silent.
Craig
Craigg is offline   Reply With Quote
Old 29-03-17, 10:11 AM   #2
Exuptoy
Default Re: Fork rebuild - squeaking
What state were the fork bushings in? (upper and lower)
Old 29-03-17, 10:53 AM   #3
Craigg
looked good, wasn't making noises before
Old 29-03-17, 08:07 PM   #4
fizzwheel
fizzwheel's Avatar
Telling us what bike this is happening on would be useful in order to help you diagnose the problem.
Old 30-03-17, 09:44 AM   #5
Craigg
yea probably!
its a K5 650 naked.
all sorted now, took the spring out and refitted it, and the noise has gone, so it must have been sitting a bit funny on the emulator and rubbing on the stanchion.
bike is all reassembled now, just need to go around and torque the bolts, then hopefully get it an MOT
Old 30-03-17, 12:28 PM   #6
Redmist
Fun fact, the reason your fork oil goes all dirty and silvery, is that the spring continuously rubs itself during travel and its the metal dust that turns the oil silvery.
Who knew!
Old 30-03-17, 02:01 PM   #7
DomP
It's quite easy to not get the emulator sitting in the damper rod cocked up at one side, I did this then wondered why the fork cap wouldn't reach the threads in the stanchion.
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Old 31-03-17, 08:23 AM   #8
Craigg
Who knew!
yea the fork oil that came out was pretty horrendous!
Old 31-03-17, 01:37 PM   #9
shiftin_gear98
shiftin_gear98's Avatar
Really must do mine...she's done quite a few miles now.
Fork rebuild problem. craig dow Bikes - Talk & Issues 10 07-10-12 05:23 PM
Extra "stiction" after fork rebuild TamSV Bikes - Talk & Issues 9 10-09-12 07:34 PM
Fork rebuild step by step muzikill Bikes - Talk & Issues 0 16-02-12 06:17 PM
Fork Rebuild Required rscosworth SV Ecosse 20 13-04-08 02:29 AM
fork rebuild adam_castell SV Talk, Tuning & Tweaking 3 19-12-07 12:50 PM
