Hi
I have just bought an sv650 ex race bike that I'm putting back on the road..does the main wiring loom have a sub loom that attaches to the front brake lever switch?..or are the front brake switch blade connectors on the main loom?.... Thank you simon |
your switchgear should connect to the main loom then there is a connector on the switchgear to connect to the brake light switch. same goes for the clutch switch.
Hi Thank you..so what your saying is the blade connections that connect to the front brake switch are on the main loom.......there is not a sub loom that connects between the main loom and connects to the switch.........
#4 | |
if the bike has had a race loom fitted you will need to buy a new loom for the bike. |
Hi
Ah ok thank you....it has the road loom,but not the sub loom as you mention,would this sub loom also be for the headlights,and do you know where I could buy one?....thanks again Simon |
its not a sub loom its the handlebar switchgear the 'loom' for them comes with the switchgear.
if the switchgear are on the bike then its had the brake switch wires cut off. yes there is also a headlight sub loom and these are different depending on if the bike was a sport or naked. Last edited by Bibio; 28-11-17 at 08:41 PM. |
Sorted it thank you...just had a look at some pics of right hand switch gear on ebay.!!...and can see the plug that goes into the brake switch!....
![]() No just need to sort the headlight!!! ![]() |
K6 Pointy Front Brake Switch | DarranID | Stuff Wanted | 0 | 01-02-16 07:23 AM |
Brake light switch sticking on with front brake | rick0361 | SV Talk, Tuning & Tweaking | 6 | 11-06-09 06:20 PM |
K6 compatible Front brake switch | Baph | Stuff Wanted | 3 | 12-02-09 11:12 PM |
Front Brake Switch - is it me?? | embee | SV Talk, Tuning & Tweaking | 8 | 01-08-05 04:21 PM |
Front brake switch? | Bikerz | SV Talk, Tuning & Tweaking | 4 | 18-05-05 07:52 AM |
