Old 06-11-19, 09:06 PM   #1
Toonleigh09
Junior Member
Default Caliper service kit??
Hi, bought an old (2000) Sv curvy with 30k miles, very little service history. Bought Hel cables and new oil and want to give the callipers a good clean as well. Thinking about a service kit and seen some on eBay with seals and pistons for about £40. Do you guys agree and eBay kit ok?? Thanks
Toonleigh09 is offline   Reply With Quote
Old 06-11-19, 09:29 PM   #2
garynortheast
garynortheast's Avatar
Default Re: Caliper service kit??
Have you had the calipers off to see how they look first. You may be ok with just a good clean up. I regularly carefully remove the seals from the callipers, clean them and put them back with a fresh coat of red rubber grease. No leak problems or degraded braking performance so far.
Similarly, the pistons may well need no more than popping out and cleaning.
What you may end up replacing though are the pad retaining pins and p clips.
Blue Curvy S with over 111,000 miles and still going strong.
Old 06-11-19, 09:30 PM   #3
Chris_SVS
Chris_SVS's Avatar
Can't really go too wrong. Are they a recognisable brand? Pretty sure I used All-balls
Chris_SVS is offline   Reply With Quote
Old 06-11-19, 09:36 PM   #4
Toonleigh09
Junior Member
Thanks, yea will probably do what your suggesting. The bikes not being used so no desperate need to get done quickly. First time doing a service so what should I be looking for wear wise?
Old 06-11-19, 09:41 PM   #5
Toonleigh09
Junior Member
Just noticed they don’t have the pistons but they are All Balls and about £35. Probably double the price with pistons
Old 06-11-19, 09:56 PM   #6
Adam Ef
Adam Ef's Avatar
Look for pitting on pistons. Any leaks around seals. If seals are good keep them as aftermarket can sometimes stick / cause problems. Make sure you put the seals back in the right way round too when you reassemble othersiwe they'll stick. As mentioned you may need new slider pins etc. You'll want red rubber grease and copper grease. If you're cleaning out the inside of the calipers then metal dental picks can be useful for getting into crevices and scraping the crud out.
Past:
Old 06-11-19, 10:12 PM   #7
Toonleigh09
Junior Member
Dental picks ordered ��
Weekend job sorted, thanks
Old 07-11-19, 07:36 AM   #8
garynortheast
The bit you need to be particularly scrupulous about are the recesses in which the dust seals locate. These recesses get a lot of oxidisation in them which pushes the dust seals out and causes them to grab the pistons. This prevents the pistons from creeping through the seals in order to take up the wear on the pads and you end up with a lot of lever travel before the brakes work. Gentles work with the dental pick and use of a brass bristled disc brush to clean out the recess thoroughly.
Old 07-11-19, 07:46 AM   #9
Adam Ef
Adam Ef's Avatar
+1 ... ^ That's the bit I was recommending the dental pick for.
Gentle on the internal ares that the seals contact. The outside is a different story. I think I remember using a chisel to remove built up crud in the main outside areas of the caliper on one occaision!
Past:
Old 07-11-19, 11:22 AM   #10
R1ffR4ff
R1ffR4ff's Avatar
If you need some Red Brake grease,
https://www.ebay.co.uk/itm/25-gram-C...kAAOSwKtlWq9-q
F + R Caliper options? CodeJACK SV Talk, Tuning & Tweaking 7 18-08-10 12:01 PM
Curvy caliper service Old Git SV Talk, Tuning & Tweaking 3 18-08-09 07:42 AM
Front Caliper Piston Service + Fluid Refill branny SV Talk, Tuning & Tweaking 23 24-01-09 01:16 PM
Citizens Service - the new National Service. grh1904 Idle Banter 11 06-09-07 11:44 AM
Service Manual for SV650S 2001 and Service Recommendation stone SV Talk, Tuning & Tweaking 1 09-05-07 04:20 PM
