Hey all, I'm planning on rebuilding my curvy S forks very soon due to a bit of a weep from one of the seals, does anyone have any recommendations for a particular supplier of the parts other than oem? Would like to avoid the cheapo import rubbish for obvious reasons.
Cheers. |
Wemoto are generally pretty good.
https://teulu.bandcamp.com/releases Blue Curvy S with over 111,000 miles and still going strong. ![]() |
Good call, hadn't thought of them.
Also ... just wanted to confirm I'm getting the ideal spring rate for the forks from the many knowledgeable peeps on here, it's good to have a second/third opinion, I'm pretty sure I'll buy the K-tech linea springs but just wanted to get some opinions and first hand experiences with this choice. Am I correct in thinking I will need the linea 9.0 springs and use the Silkolene RSF 10w fork oil? Is this a good combo? BTW... I weigh 12 stone clothed but not bike gear, I expect when fully geared up I will be in the region of 13 stone. Bike is mainly used for a bit of 'spirited' riding only ... and maybe the odd track day. Any help with this choice before I commit to buy would be really helpful. Cheers. |
I reckon you're probably spot on for a comfortable/firm road spec. If your bike has std forks at present you'll find a huge improvement.
You might want to check out K-Tech springs, not expensive & they do different ones for different rider weights, I just got some after a recommendation on an FB SV group, not fitted them yet tho, thinking of welding the damper holes up while I'm at it.
#7 | |
Just got to strip it all down now and get it all up 'n' running. So |
Ive just soldered my damper rod holes rather than weld and it seemed to have worked quite well although I cant detect much difference in performance. To me as standard its always felt pretty good but I was changing the oil so thought Id do the mod as well.
I drilled a slight countersink in the holes, melted a blob on the end of a short length of solder and pushed it through so the blob ended up on the inside. Then I puddled the solder in the external countersink and filed it smooth. Cant see why it shouldnt be a permanent seal but as I say its such a small hole I cant see it makes much difference to rebound damping... |
#9 | |
Fork rebuild - squeaking | Craigg | Bikes - Talk & Issues | 8 | 31-03-17 01:37 PM |
Fork rebuild problem. | craig dow | Bikes - Talk & Issues | 10 | 07-10-12 05:23 PM |
Extra "stiction" after fork rebuild | TamSV | Bikes - Talk & Issues | 9 | 10-09-12 07:34 PM |
Fork Rebuild Required | rscosworth | SV Ecosse | 20 | 13-04-08 02:29 AM |
fork rebuild | adam_castell | SV Talk, Tuning & Tweaking | 3 | 19-12-07 12:50 PM |
