hi im a neewbee just got 98/99 650s and it resrticted to 190kph i think its a jap import only payed £1400 for it and shes aminter will happy with it bit why is it that it wont pull over 190kph in 5th or 6th gears and yes that is down hill with the wind behind you. wheelies a good can get her up in 1st and click into 2nd but she dont like 3rd need help as my mates one is not resrticted
Well that's about 120 mph which is close to the SV's top speed unless you're wrapped around the tank and have a tail-wind. Some bikes are slightly faster than others anyway.
#3 | |
no bike only pulls 9500 in top or 10500 in 5th and yes downhill wind behind me yes it has some form of speed restiction i think its from japan well i know all suzukis are but this ones for jap market . disconected speedo and mess about with th three gear postion wires and if i disconnect pink one it only revs to 8500 in any gear
I don't have an sv, so correct me if I'm wrong here, but...
A lot of times vehicles don't pull to the redline in the top gear. It's because the engine doesn't have enough power to get through such a tall gear ratio. Sometimes, depending on the gear ratio, top speed is acheived through 5th gear instead of 6th. Try getting a different sprocket to shorten up the gear ratio a little and that might allow it to get through 6th gear. (unless sv's are supposed to be able to redline 6th gear, in which case all of the above should be ignored!) |
and why would you want to 'wheelie' ?
why wheelie because i can, remeber lifes to short to **** about wishing why, if and maybe. like the man said just do it
#8 | |
However, after some mild porting, skimming the heads, race filter and Jets, full system and G-pak, mine now pulls all the way through until about 11,250 or so in every gear except top with no drop off of power before the limiter cuts in. and although the final drive gearing has been changed (46 rear) it will still do 131mph (averaged over both ways, three GPS's, two escorteing bikes, and six runs). I've just looked it up and your 190kph is 118.1 Mph so I would say it's restricted somehow whether that's because it's not running right or not I don't know, first I'd check the timing, valaves and basics out,after that maybe see if you can borrow a G-pak and give it a try ![]() or borrow a set of carbs ![]() the restriction could be just about anywhere. But normally it's either exhaust, inlet (carbs or sometimes the rubber inlets beneth the carbs) airbox or electronuics. Less likely is things like cam profiles and timing issues, but possible ![]() Cheers Mark.
#9 |
cheers mark no it electrical for sure think im gona try uk cdi if not **** knows maybe have it on the rollers and try and find out where its coming from ther a few stange things about it like only three wires from gear postion swicth thanks for help
#10 | |
![]() i forget....its big and its clever... must remember that one.. {walks away shaking head} |
Slow?? | SV PILOT | Bikes - Talk & Issues | 20 | 14-05-08 11:25 PM |
You know you are having a slow day when..... | SoulKiss | Idle Banter | 13 | 01-03-08 10:56 AM |
Anyone else having a slow monday? | Baph | Idle Banter | 0 | 19-02-07 12:28 PM |
Slow Internet | Reckless Rat | Idle Banter | 7 | 23-08-06 10:19 PM |
